Well, Terry, I don't really see any electronic difference in using the old field coil as an inductor, except that it will be a lot bigger than a "store bought" one, and you will have a one heck of an electromagnet there, for whatever you might can think of to use it for.
Terry,
Can you fabricate a backer board to increase the overall thickness to support the original speaker? It will not be seen from the outside and can be stained to match the inside of the cabinet. Good to hear from you.
Jon.
:Terry: You'll have to post some pix for us to see when you are done. And sorry to hear about your injury. Hope there are no lasting effects Mark from Kalamazoo
: : : : ![]() : : : : : : : :Sir Terry . . . . . : : :Mmmmmmm . . . ehhhh . . . What's up Doc ? . . . long see . . . . no time ? : : :I could only find a photo of a back cabinet view of an 18 -14 unit, any chance that the speakers are alike in the respect of using a square field coil basket and possibly are being about the same size ? . . . . . . . . . . : : : : ![]() : : : : : : :How about this possibility . . . . as it certainly looks like that unit has one substantial top on it. : : :Is it feasible to consider the possibility of mounting an upwards to maybe 2 inch thick by 6X6---8X8 square ? . . . vat you thinks ? . . . . hardwood block at the tops underside, with "scrue and glews" . :Then . . . in looking at that speaker . . . it appears that its front / to rear center of gravity will be occuring about three quarters of the way to the rear of the unit. : : :One then forms a right angle inverted square "U" bracket from sheet metal to then reach down and mount to the two sides of the speaker frame and fasten/screw/clamp . . . onto/into it. : : :The MAIN mechanical support of the speaker will THEN be accomplished with that mount, and the then transition of minimal dependence upon the 4 frontal mounting plate screws of the speaker proper. : : :Ultra flat black paint . . . OR . . .a matte coloring to the existing finish of the obscured inside bottom of the top, somewhat disguises the support mechanica presence : : : : : : : :73's de Edd : : : ![]() : |
:: :: :: :: ![]() :: :: :: :: :: :: :: ::Sir Terry . . . . . :: :: ::Mmmmmmm . . . ehhhh . . . What's up Doc ? . . . long see . . . . no time ? :: :: ::I could only find a photo of a back cabinet view of an 18 -14 unit, any chance that the speakers are alike in the respect of using a square field coil basket and possibly are being about the same size ? . . . . . . . . . . :: :: :: :: ![]() :: :: :: :: :: :: ::How about this possibility . . . . as it certainly looks like that unit has one substantial top on it. :: :: ::Is it feasible to consider the possibility of mounting an upwards to maybe 2 inch thick by 6X6---8X8 square ? . . . vat you thinks ? . . . . hardwood block at the tops underside, with "scrue and glews" . ::Then . . . in looking at that speaker . . . it appears that its front / to rear center of gravity will be occuring about three quarters of the way to the rear of the unit. :: :: ::One then forms a right angle inverted square "U" bracket from sheet metal to then reach down and mount to the two sides of the speaker frame and fasten/screw/clamp . . . onto/into it. :: :: ::The MAIN mechanical support of the speaker will THEN be accomplished with that mount, and the then transition of minimal dependence upon the 4 frontal mounting plate screws of the speaker proper. :: :: ::Ultra flat black paint . . . OR . . .a matte coloring to the existing finish of the obscured inside bottom of the top, somewhat disguises the support mechanica presence :: :: :: :: :: :: :: ::73's de Edd :: :: :: ![]() :: |
::: ::: ::: ::: ![]() ::: ::: ::: ::: ::: ::: ::: :::Sir Terry . . . . . ::: ::: :::Mmmmmmm . . . ehhhh . . . What's up Doc ? . . . long see . . . . no time ? ::: ::: :::I could only find a photo of a back cabinet view of an 18 -14 unit, any chance that the speakers are alike in the respect of using a square field coil basket and possibly are being about the same size ? . . . . . . . . . . ::: ::: ::: ::: ![]() ::: ::: ::: ::: ::: ::: :::How about this possibility . . . . as it certainly looks like that unit has one substantial top on it. ::: ::: :::Is it feasible to consider the possibility of mounting an upwards to maybe 2 inch thick by 6X6---8X8 square ? . . . vat you thinks ? . . . . hardwood block at the tops underside, with "scrue and glews" . :::Then . . . in looking at that speaker . . . it appears that its front / to rear center of gravity will be occuring about three quarters of the way to the rear of the unit. ::: ::: :::One then forms a right angle inverted square "U" bracket from sheet metal to then reach down and mount to the two sides of the speaker frame and fasten/screw/clamp . . . onto/into it. ::: ::: :::The MAIN mechanical support of the speaker will THEN be accomplished with that mount, and the then transition of minimal dependence upon the 4 frontal mounting plate screws of the speaker proper. ::: ::: :::Ultra flat black paint . . . OR . . .a matte coloring to the existing finish of the obscured inside bottom of the top, somewhat disguises the support mechanica presence ::: ::: ::: ::: ::: ::: ::: :::73's de Edd ::: ::: ::: ![]() ::: |
:::: :::: :::: :::: ![]() :::: :::: :::: :::: :::: :::: :::: ::::Sir Terry . . . . . :::: :::: ::::Mmmmmmm . . . ehhhh . . . What's up Doc ? . . . long see . . . . no time ? :::: :::: ::::I could only find a photo of a back cabinet view of an 18 -14 unit, any chance that the speakers are alike in the respect of using a square field coil basket and possibly are being about the same size ? . . . . . . . . . . :::: :::: :::: :::: ![]() :::: :::: :::: :::: :::: :::: ::::How about this possibility . . . . as it certainly looks like that unit has one substantial top on it. :::: :::: ::::Is it feasible to consider the possibility of mounting an upwards to maybe 2 inch thick by 6X6---8X8 square ? . . . vat you thinks ? . . . . hardwood block at the tops underside, with "scrue and glews" . ::::Then . . . in looking at that speaker . . . it appears that its front / to rear center of gravity will be occuring about three quarters of the way to the rear of the unit. :::: :::: ::::One then forms a right angle inverted square "U" bracket from sheet metal to then reach down and mount to the two sides of the speaker frame and fasten/screw/clamp . . . onto/into it. :::: :::: ::::The MAIN mechanical support of the speaker will THEN be accomplished with that mount, and the then transition of minimal dependence upon the 4 frontal mounting plate screws of the speaker proper. :::: :::: ::::Ultra flat black paint . . . OR . . .a matte coloring to the existing finish of the obscured inside bottom of the top, somewhat disguises the support mechanica presence :::: :::: :::: :::: :::: :::: :::: ::::73's de Edd :::: :::: :::: ![]() :::: |
::::73's de Edd
:::::Terry: You'll have to post some pix for us to see when you are done. And sorry to hear about your injury. Hope there are no lasting effects Mark from Kalamazoo
:::Thanks edd. If I understand it, one of your suggestions is mounting a board inside the cabinet to support the weight of the field coil. That is the most sensible idea yet, and one I never would have thought of.
:::However, there's still the problem of the completely trashed cone.
:::< src=http://a4.l3-images.myspacecdn.com/images02/146/32b327c30a3c4115a96db5963f492789/m.jpg>
::Okay-let's try the photo again-
::::: ::::: ::::: ::::: ![]() ::::: ::::: ::::: ::::: ::::: ::::: ::::: :::::Sir Terry . . . . . ::::: ::::: :::::Mmmmmmm . . . ehhhh . . . What's up Doc ? . . . long see . . . . no time ? ::::: ::::: :::::I could only find a photo of a back cabinet view of an 18 -14 unit, any chance that the speakers are alike in the respect of using a square field coil basket and possibly are being about the same size ? . . . . . . . . . . ::::: ::::: ::::: ::::: ![]() ::::: ::::: ::::: ::::: ::::: ::::: :::::How about this possibility . . . . as it certainly looks like that unit has one substantial top on it. ::::: ::::: :::::Is it feasible to consider the possibility of mounting an upwards to maybe 2 inch thick by 6X6---8X8 square ? . . . vat you thinks ? . . . . hardwood block at the tops underside, with "scrue and glews" . :::::Then . . . in looking at that speaker . . . it appears that its front / to rear center of gravity will be occuring about three quarters of the way to the rear of the unit. ::::: ::::: :::::One then forms a right angle inverted square "U" bracket from sheet metal to then reach down and mount to the two sides of the speaker frame and fasten/screw/clamp . . . onto/into it. ::::: ::::: :::::The MAIN mechanical support of the speaker will THEN be accomplished with that mount, and the then transition of minimal dependence upon the 4 frontal mounting plate screws of the speaker proper. ::::: ::::: :::::Ultra flat black paint . . . OR . . .a matte coloring to the existing finish of the obscured inside bottom of the top, somewhat disguises the support mechanica presence ::::: ::::: ::::: ::::: ::::: ::::: ::::: :::::73's de Edd ::::: ::::: ::::: ![]() ::::: |
:::::: :::::: :::::: :::::: ![]() :::::: :::::: :::::: :::::: :::::: :::::: :::::: ::::::Sir Terry . . . . . :::::: :::::: ::::::Mmmmmmm . . . ehhhh . . . What's up Doc ? . . . long see . . . . no time ? :::::: :::::: ::::::I could only find a photo of a back cabinet view of an 18 -14 unit, any chance that the speakers are alike in the respect of using a square field coil basket and possibly are being about the same size ? . . . . . . . . . . :::::: :::::: :::::: :::::: ![]() :::::: :::::: :::::: :::::: :::::: :::::: ::::::How about this possibility . . . . as it certainly looks like that unit has one substantial top on it. :::::: :::::: ::::::Is it feasible to consider the possibility of mounting an upwards to maybe 2 inch thick by 6X6---8X8 square ? . . . vat you thinks ? . . . . hardwood block at the tops underside, with "scrue and glews" . ::::::Then . . . in looking at that speaker . . . it appears that its front / to rear center of gravity will be occuring about three quarters of the way to the rear of the unit. :::::: :::::: ::::::One then forms a right angle inverted square "U" bracket from sheet metal to then reach down and mount to the two sides of the speaker frame and fasten/screw/clamp . . . onto/into it. :::::: :::::: ::::::The MAIN mechanical support of the speaker will THEN be accomplished with that mount, and the then transition of minimal dependence upon the 4 frontal mounting plate screws of the speaker proper. :::::: :::::: ::::::Ultra flat black paint . . . OR . . .a matte coloring to the existing finish of the obscured inside bottom of the top, somewhat disguises the support mechanica presence :::::: :::::: :::::: :::::: :::::: :::::: :::::: ::::::73's de Edd :::::: :::::: :::::: ![]() :::::: |
