Radiola 80/82 audio interstage and output xformers
7/5/2011 5:18:46 PMBen F
I am restoring a Radiola 80/82 and need help with a recommendation for a replacement audio interstage transformer that connects the pushpull 45 tube grids. Also, need a recommendation for the output transformer. The original transformers have open windings and are housed in a metal can sealed with tar. Thanks in advance for your help.
7/6/2011 5:17:05 PMClifton
Ben,
You might try Radio Daze @:
http://www.radiosupply.com/
or Antique Electronic Supply @:
http://www.tubesandmore.com
They have some replacement transformers.
Clifton {:o)<--
:I am restoring a Radiola 80/82 and need help with a recommendation for a replacement audio interstage transformer that connects the pushpull 45 tube grids. Also, need a recommendation for the output transformer. The original transformers have open windings and are housed in a metal can sealed with tar. Thanks in advance for your help.
7/6/2011 6:54:16 PMMmakazoo
I have a westinghouse wr8 which is similar to the radiola 82. Got an interstage audio transformer from AES and mounted it under the chassis with the original can on top. It is quite small and there was plenty of room to mount it. Mark from Kalamazoo
7/7/2011 7:45:12 AMBen F
:I have a westinghouse wr8 which is similar to the radiola 82. Got an interstage audio transformer from AES and mounted it under the chassis with the original can on top. It is quite small and there was plenty of room to mount it. Mark from Kalamazoo
Thanks for the suggestions. I have looked at the transformers that are available from Radio Daze and was not sure what impedance values or part numbers to use. Thanks again for your help.
7/8/2011 3:44:27 PMBen F
:Ben,
:You might try Radio Daze @:
:http://www.radiosupply.com/
:or Antique Electronic Supply @:
:http://www.tubesandmore.com
:They have some replacement transformers.
:Clifton {:o)<--
:Clifton and Mark, many thanks for your help. I contacted Radio Daze's tech dept and they gave me their recommended replacement xformers. The interstage is HX-124A and the output is HX-125E.
::I am restoring a Radiola 80/82 and need help with a recommendation for a replacement audio interstage transformer that connects the pushpull 45 tube grids. Also, need a recommendation for the output transformer. The original transformers have open windings and are housed in a metal can sealed with tar. Thanks in advance for your help.
