NEED A GEAR....ANYONE HAVE???
6/14/2011 2:10:52 AMgeorge
I posted a while back that i needed a gear for my Airline "movie dial" drive...I am still searching at clock shops and old V.C.R.s ect. ect... with no luck...I need a gear that is 1 9/16 in diameter with 72 teeth...shft size does not matter...original was fiber..would prefer steel
6/14/2011 12:53:13 PMMarv Nuce
Geo,
Last time it was 1.5" dia w/82 teeth. Are you sure?
:I posted a while back that i needed a gear for my Airline "movie dial" drive...I am still searching at clock shops and old V.C.R.s ect. ect... with no luck...I need a gear that is 1 9/16 in diameter with 72 teeth...shft size does not matter...original was fiber..would prefer steel
6/14/2011 1:17:28 PMGeorge sorry marv
Yah it is 1 9/16 with 72 teeth...stubborn me did not have my glasses on
6/14/2011 1:50:10 PMMarv Nuce
Yea, I know 'bout the glasses thing, even though they're hanging around my neck. I'll look at my gear stock again.
:Yah it is 1 9/16 with 72 teeth...stubborn me did not have my glasses on
6/14/2011 6:40:23 PMMarv Nuce
Zero, zip, nada, nothing.
:Yea, I know 'bout the glasses thing, even though they're hanging around my neck. I'll look at my gear stock again.
:marv
::Yah it is 1 9/16 with 72 teeth...stubborn me did not have my glasses on
6/15/2011 5:28:42 PMMarv Nuce
Geo.
Assume you're not interested in authenticity, since you opted for a steel gear vs the orig fiber. Google Studio Sound Elect, and look at their selection of rubber tires/belts for old electro-mechanical sound reproducers. Might be able to retread your fiber wheel with a new rubber tire, if you reduce it's dia. As long as OD is near the orig, should mesh well with gears, and retain turns ratio. May require a little experimentation though.
6/15/2011 7:44:14 PMgeorge to marv
Now thats an idea....Dam won't work.. It wont work because the small spur gear off the motor directly drives the fiber gear...The small spur gear doesn't have enough friction to drive whole thing...DAM
