The negative side of the high voltage supply is B-.
It uses the letter B because back when radios were powered by batteries, the batteries were assigned the first 3 letters of the alphabet--A for the filament battery, B for the plate supply battery, and C for the bias battery. Rarely will you find electric radios with a separate C supply, as it is often configured into the B supply.
So it really means the supply the Voltage comes from, not where it goes or what it does. So,
A can also go to pilot lights, B to screens, and C used to be supplied by a bias cell, but as mentioned above it is done by resistors these days.
