Spotlight Bulb
5/21/2011 9:20:24 PMjim l
Would anyone know type, voltage of spotlite bulb in Weller 8200 soldering gun??
5/21/2011 10:11:35 PMWarren
It's a 222 ... 2.25 volt .25 amp
5/22/2011 5:21:49 AMLewis L
:It's a 222 ... 2.25 volt .25 amp
It was originally intended for pen lights, has found uses in lots of other things....very common.
5/22/2011 7:51:42 AMjim l
::It's a 222 ... 2.25 volt .25 amp
:It was originally intended for pen lights, has found uses in lots of other things....very common.
:Lewis
5/22/2011 7:53:03 AMjim l
:::It's a 222 ... 2.25 volt .25 amp
::It was originally intended for pen lights, has found uses in lots of other things....very common.
::Lewis
::Thanks men. Will rob penlites or ck at the Shack
5/23/2011 3:47:47 PMEdd
Sir Jim I . . . . .
And with your unit possibly having a sole lamp or possibly you having the larger version of gun which is using a spaced apart tandem pair.
ORRRRR . . . on my frequent situations, its usually just a lamp loosening up in its rinky dink socket which they incorporated into the unit.
ALSO . . . Its a bit harder than usual to get a GOOD firm grip on that 222 mini concave / lens tipped envelope !
PLUS . . . .And I do see some of the later units (8200, etc ) is now using a different lamp. . . . . which has the same frontal bulb envelope profile as # 47/#44 . . . but this unit is using a 7194 wedge type of bulb and its basing.
::::It's a 222 ... 2.25 volt .25 amp
:::It was originally intended for pen lights, has found uses in lots of other things....very common.
:::Lewis
:::Thanks men. Will rob penlites or ck at the Shack
