73 ohms on find number 8 bakelite block??
5/9/2011 8:57:10 AMLou
I am continuing my work on a Philco Model 20.
I have founf a bakelite block ( schematic f/n 8 ) that has a 250 ohm resistor that measures 73 ohms??, and a shorted 0.05 uF capacitor. One question for the group - I understand the shorted cap after all these years but HOW does a 250 ohm resistor magically become 73 ohms? Yes by the way this unit is disconnected from other circuitry.
Puzzled - Thanks
Lou
5/9/2011 10:34:05 AMNorm Leal
Hi Lou
Philco used a small coil of wire instead of actual resistor in some blocks. Maybe insulation came off the wire.
:I am continuing my work on a Philco Model 20.
:I have founf a bakelite block ( schematic f/n 8 ) that has a 250 ohm resistor that measures 73 ohms??, and a shorted 0.05 uF capacitor. One question for the group - I understand the shorted cap after all these years but HOW does a 250 ohm resistor magically become 73 ohms? Yes by the way this unit is disconnected from other circuitry.
:Puzzled - Thanks
:Lou
5/9/2011 11:16:09 AMLou
Whew:
Thanks for telling me. I thought I was seeing things!!
Lou
:Hi Lou
: Philco used a small coil of wire instead of actual resistor in some blocks. Maybe insulation came off the wire.
::I am continuing my work on a Philco Model 20.
::I have founf a bakelite block ( schematic f/n 8 ) that has a 250 ohm resistor that measures 73 ohms??, and a shorted 0.05 uF capacitor. One question for the group - I understand the shorted cap after all these years but HOW does a 250 ohm resistor magically become 73 ohms? Yes by the way this unit is disconnected from other circuitry.
::Puzzled - Thanks
::Lou
