Admiral mod 66m5
5/7/2011 12:31:35 PMMitch
Hello all,
Can you tell me where i can find a schematic for this radio?
Mitch
5/7/2011 1:02:57 PMCarl T
:Hello all,
:Can you tell me where i can find a schematic for this radio?
:Thanks
:Mitch
Mitch,
Is there a chassis number on the radio?
Carl T
5/7/2011 4:57:00 PMMitch
::Hello all,
::Can you tell me where i can find a schematic for this radio?
::Thanks
::Mitch
:Mitch,
:Is there a chassis number on the radio?
:Carl T
Looks like the chassis # is D-4682, tube lineup is 12sa7, 12sk7, 12sq7, 35z5, 50l6.
It was lisenced by RCA.
Where i really need help is in the antenna circuirty, the rear of the radio panel has crumbled into pieces. I have a hand full of antenna wire that has opens in it and loose wires from the radio. I can rebuild the back but need some info on how to rewire and connect the antenna.
Mitch
5/7/2011 6:44:20 PMCarl T
:::Hello all,
:::Can you tell me where i can find a schematic for this radio?
:::Thanks
:::Mitch
::Mitch,
::Is there a chassis number on the radio?
::Carl T
:Looks like the chassis # is D-4682, tube lineup is 12sa7, 12sk7, 12sq7, 35z5, 50l6.
:It was lisenced by RCA.
:Where i really need help is in the antenna circuirty, the rear of the radio panel has crumbled into pieces. I have a hand full of antenna wire that has opens in it and loose wires from the radio. I can rebuild the back but need some info on how to rewire and connect the antenna.
:Thanks
:Mitch
Mitch,
Try this schematic:
http://www.nostalgiaair.org/PagesByModel/103/M0003103.pdf
Carl T
5/7/2011 7:25:31 PMMitch
::::Hello all,
::::Can you tell me where i can find a schematic for this radio?
::::Thanks
::::Mitch
:::Mitch,
:::Is there a chassis number on the radio?
:::Carl T
::Looks like the chassis # is D-4682, tube lineup is 12sa7, 12sk7, 12sq7, 35z5, 50l6.
::It was lisenced by RCA.
::Where i really need help is in the antenna circuirty, the rear of the radio panel has crumbled into pieces. I have a hand full of antenna wire that has opens in it and loose wires from the radio. I can rebuild the back but need some info on how to rewire and connect the antenna.
::Thanks
::Mitch
:Mitch,
:Try this schematic:
:http://www.nostalgiaair.org/PagesByModel/103/M0003103.pdf
:Carl T
Thanks Carl T,
This schematic will work just great for the antenna and some checking on tube voltages. With a makeshift antenna i was able to get a few stations.
The dial lamp is a #45 and is burned out, I have some #47's, can I use a #47 with no harm to the filaments?
Mitc
5/7/2011 11:31:41 PMWarren
#45 is only a 3 volt bulb. That's why it's burnt out.
A #47 or #44 is what it should of had anyway.
5/8/2011 11:12:30 AMNorm Leal
Hi
Since a #45 bulb burnt out check continuity of 35Z5 filament between pin #2 and #7. The bulb will be wired across a section of this filament.
Even though a #45 bulb is 3 volts it requires a current of .5 amps. This circuit can only supply enough current for a #47 bulb, .15 amps, or similar. The #45 would act like a fuse rather than bulb.
: #45 is only a 3 volt bulb. That's why it's burnt out.
:A #47 or #44 is what it should of had anyway.
