4 tube trf table radio 1934-1935 capacitor
5/2/2011 10:54:03 PMdustin
The big electrolytic metal can on top of the chassis has two black neg wire and one red pos wire does this sound right? Hooked up two 4mfd 450v common positive and separate negatives turned it on and hisses and crackles????????
5/2/2011 11:02:11 PMNorm Leal
Hi Dustin
You must have them in correctly. If reversed caps would have heated and blown. Probably before the radio had a chance to crackle.
What model radio? Schematics for most radios are here on nostalgiaair.
:The big electrolytic metal can on top of the chassis has two black neg wire and one red pos wire does this sound right? Hooked up two 4mfd 450v common positive and separate negatives turned it on and hisses and crackles????????
5/2/2011 11:03:19 PMdustin
:Hi Dustin
: You must have them in correctly. If reversed caps would have heated and blown. Probably before the radio had a chance to crackle.
: What model radio? Schematics for most radios are here on nostalgiaair.
::The big electrolytic metal can on top of the chassis has two black neg wire and one red pos wire does this sound right? Hooked up two 4mfd 450v common positive and separate negatives turned it on and hisses and crackles????????
5/2/2011 11:06:29 PMdustin
::Hi Dustin
:: You must have them in correctly. If reversed caps would have heated and blown. Probably before the radio had a chance to crackle.
:: What model radio? Schematics for most radios are here on nostalgiaair.
::western auto supply los angeles model 17 I cant find any pictures of it or info on it. I think it might be another brand name under western auto supply.
:::The big electrolytic metal can on top of the chassis has two black neg wire and one red pos wire does this sound right? Hooked up two 4mfd 450v common positive and separate negatives turned it on and hisses and crackles????????
5/2/2011 11:47:09 PMPeter G. Balazsy
Gilfillan Made some radios for Western Auto....
What's the tube line up?
Take a look at the Gilfillan 410 as an example. Might be close.
Sometimes you'll see a model number stamped on the back right of the metal chassis if it's a Gilfillan number.
5/2/2011 11:58:40 PMdustin
:Gilfillan Made some radios for Western Auto....
:What's the tube line up?
:Take a look at the Gilfillan 410 as an example. Might be close.
:Sometimes you'll see a model number stamped on the back right of the metal chassis if it's a Gilfillan number.
:Just found it here! Its a western air patrol model 17. Great website. Still cant understand what is wrong I replaced all the caps and me being a novice in radio repair im stumped on two caps it calls for in the diagram c7 and c8. I believe they are the ones in the can on top of the chassis. Thanks for helping me out tonight.
5/3/2011 12:57:51 AMThomas Dermody
http://www.nostalgiaair.org/PagesByModel/560/M0023560.pdf
First off I would like to point out that what the schematic calls out as G2 should really be G1 for all tubes, and what is G1 should be G2. I am not sure why some early schematics are drawn in this way. Actually this is the first schematic in which I have seen G1 and G2 transposed, but I have seen schematics were G2 and G3 are transposed, and I believe that either G2 or G3 is shown surrounding the plate. I'm not sure. In reality some RF pentodes will have a shield around the plate that is tied to the supressor grid, but in the schematics I saw where they were transposed, this 'double grid,' if you will call it, was actually connected as G2 would have been connected.
Anyway, aside from that, C4 and C5 are sometimes prone to arcing, and will both cause crackling and possibly a complete absence of audio signal. C3 usually doesn't arc over due to the high impedances on both sides of the capacitor, but rather normally causes distortion and run-away current in the output tube. It could possibly arc over, though. C2 could arc, and would possibly wipe out reception if arcing was bad enough.
For reliable operation replace all of these capacitors. Also remember that what the schematic shows as G1 should be G2, and what the schematic shows as G2 should be G1. (...Though I could be completely wrong, and the set may in fact be wired exactly as the schematic shows, but in any other set the grids would be wired as I said... ....Normally connecting G1 to a positive voltage, especially in excess of 25, 45, or 200 volts, will cause the tube to run away with current.)
5/3/2011 5:18:46 PMdustin
:http://www.nostalgiaair.org/PagesByModel/560/M0023560.pdf
:First off I would like to point out that what the schematic calls out as G2 should really be G1 for all tubes, and what is G1 should be G2. I am not sure why some early schematics are drawn in this way. Actually this is the first schematic in which I have seen G1 and G2 transposed, but I have seen schematics were G2 and G3 are transposed, and I believe that either G2 or G3 is shown surrounding the plate. I'm not sure. In reality some RF pentodes will have a shield around the plate that is tied to the supressor grid, but in the schematics I saw where they were transposed, this 'double grid,' if you will call it, was actually connected as G2 would have been connected.
:Anyway, aside from that, C4 and C5 are sometimes prone to arcing, and will both cause crackling and possibly a complete absence of audio signal. C3 usually doesn't arc over due to the high impedances on both sides of the capacitor, but rather normally causes distortion and run-away current in the output tube. It could possibly arc over, though. C2 could arc, and would possibly wipe out reception if arcing was bad enough.
:For reliable operation replace all of these capacitors. Also remember that what the schematic shows as G1 should be G2, and what the schematic shows as G2 should be G1. (...Though I could be completely wrong, and the set may in fact be wired exactly as the schematic shows, but in any other set the grids would be wired as I said... ....Normally connecting G1 to a positive voltage, especially in excess of 25, 45, or 200 volts, will cause the tube to run away with current.)
The 2A5 tube arcing!
5/3/2011 6:52:18 PMEdd
Sir Dustin . . . . .
You do have your pilots license to be working on that unit . . . . it being a WESTERN AIR PATROL unit, they are quite critical on their maintenance personnel /standards . . . . ('jes messin wit' your mind !).
I think I see your :
" I'm stumped on two caps it calls for in the diagram c7 and c8. I believe they are the ones in the can on top of the chassis. "
being yet unanswered..
But yes, your install procedures described . . . with the common positives and the two separate negatives, with one negative lead then going to both the center tap of the HV secondary winding of the power transformer/and/ the input of the speakers field coil winding.
With the other negative lead going to chassis ground.
One other thought . . . is for you to check out the 400 ohm power resistor to ground, which is on the other side of that speakers field coil winding, to see if there is no possibility of it having opened up.
Now, lets see if we can temporarily go over to the W19 chassis and just refer to its power supply and audio output circuitry for comparison.
Thats :
> > > (I'm one HOT little Link . . .go ahead . .just touch me ! ) < < <
Initially we see that your W17 schematic specified the units as being two parts within a canned unit and the C7 and C8 designations . . . . but if you refer to the W17 schematic, they will give you the units proper installed polarity markings (but no C7-C8 mark ups ! ). You have that aspect all deduced out already.
The other aspect is what Sir Thomas has mentioned up at the audio output circuitry, on your consulting the W19 schematic on the wiring in the 2A3's . . . Grid 1-Grid 2 . . areas and you will then see that which was mentioned.
Really just waiting now . . . to see if you found that 400 ohm resistor intact as well as what your actual DC voltage readings are on the input and the output of the speaker field coil windings.
Also confirm that 400 ohm resistor, it additionally should have a NEGATIVE voltage developed across it, when being referenced to ground.
Standing by . . .
::http://www.nostalgiaair.org/PagesByModel/560/M0023560.pdf
::First off I would like to point out that what the schematic calls out as G2 should really be G1 for all tubes, and what is G1 should be G2. I am not sure why some early schematics are drawn in this way. Actually this is the first schematic in which I have seen G1 and G2 transposed, but I have seen schematics were G2 and G3 are transposed, and I believe that either G2 or G3 is shown surrounding the plate. I'm not sure. In reality some RF pentodes will have a shield around the plate that is tied to the supressor grid, but in the schematics I saw where they were transposed, this 'double grid,' if you will call it, was actually connected as G2 would have been connected.
::Anyway, aside from that, C4 and C5 are sometimes prone to arcing, and will both cause crackling and possibly a complete absence of audio signal. C3 usually doesn't arc over due to the high impedances on both sides of the capacitor, but rather normally causes distortion and run-away current in the output tube. It could possibly arc over, though. C2 could arc, and would possibly wipe out reception if arcing was bad enough.
::For reliable operation replace all of these capacitors. Also remember that what the schematic shows as G1 should be G2, and what the schematic shows as G2 should be G1. (...Though I could be completely wrong, and the set may in fact be wired exactly as the schematic shows, but in any other set the grids would be wired as I said... ....Normally connecting G1 to a positive voltage, especially in excess of 25, 45, or 200 volts, will cause the tube to run away with current.)
:The 2A5 tube arcing!
5/4/2011 2:16:02 AMThomas Dermody
Dustin, if the 2A5 is arcing, I would run an element-to-element shorts test on a tube tester with this tube. I would also check to see if the input audio capacitor is leaky (or just replace it, because you should). If it is leaky, this will cause the tube to run away with current. Arcing can occur from the cathode to the screen grid or plate, or between the cathode and the control grid.
Definitely be sure that G1 on all tubes is wired as the signal grid, and that G2 on all tubes is wired as the screen grid, and is connected to the B+ circuitry as shown in the schematic. If you connect G1 of any tube, especially the output tube, to B+, you will likely get arcing, and may destroy the tube. I would hope that the manufacturer did not wire the grids as shown in the schematic, and I hope that any previous repairmen didn't alter wiring to match the schematic, because it is wrong as shown.
5/7/2011 10:33:10 PMdustin
:Dustin, if the 2A5 is arcing, I would run an element-to-element shorts test on a tube tester with this tube. I would also check to see if the input audio capacitor is leaky (or just replace it, because you should). If it is leaky, this will cause the tube to run away with current. Arcing can occur from the cathode to the screen grid or plate, or between the cathode and the control grid.
:Definitely be sure that G1 on all tubes is wired as the signal grid, and that G2 on all tubes is wired as the screen grid, and is connected to the B+ circuitry as shown in the schematic. If you connect G1 of any tube, especially the output tube, to B+, you will likely get arcing, and may destroy the tube. I would hope that the manufacturer did not wire the grids as shown in the schematic, and I hope that any previous repairmen didn't alter wiring to match the schematic, because it is wrong as shown.
:T.
Replaced the 2a5 and works great. thanks for all the help.
