I'm wondering what you plan to use this thing for?
:Google "HP 212A" - and this link is at the top of the list: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-02.pdf There are many other links, too. Google is your friend.
:I'm wondering what you plan to use this thing for?
Check it out:
Hewlett Packard 212A Pulse Generator – Tube Compliment
V1 6X4 V14 0B2
V2 6L6GB V15 6AU6
V3 6W4GT V16 HP45
V4 0B2 V17A,B 6AS7G
V5 N/A V18 thru 100 N/A
V6 HP45 V101 thru V109 12AU7, 5963, OR 7316
V7,8,9 6J6 N/A = not assigned
V10 12AX7
V11 6AS7G
V12 OD3
V13 5U4GB
Clifton
:Doug,
:I have seen this page but it gives me no information about what tubes are in it at all. Just the special hydrogen thyratron. But no numbers. I have searched the internet with google and there is no other information about this model at all that I can find. There is no service data for it in BAMA either. So what would I use it for? Just learning. But I probably wont have it very long. It has too many "droppings" inside. I don't want to touch that. Plus it's huge. I'll give it to someone and he'll tell me what tubes are in it by looking more closely at it.
:Thanks,
:Dave
::Google "HP 212A" - and this link is at the top of the list: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-02.pdf There are many other links, too. Google is your friend.
::I'm wondering what you plan to use this thing for?
Cut and past didn't work right, so try again:
V1 6X4 V14 0B2
V2 6L6GB V15 6AU6
V3 6W4GT V16 HP45
V4 0B2 V17A,B 6AS7G
V10 12AX7
V11 6AS7G
V12 OD3
V13 5U4GB
Clifton
:Dave,
:Check it out:
:Hewlett Packard 212A Pulse Generator – Tube Compliment
:V1 6X4 V14 0B2
:V2 6L6GB V15 6AU6
:V3 6W4GT V16 HP45
:V4 0B2 V17A,B 6AS7G
:V5 N/A V18 thru 100 N/A
:V6 HP45 V101 thru V109 12AU7, 5963, OR 7316
:V7,8,9 6J6 N/A = not assigned
:V10 12AX7
:V11 6AS7G
:V12 OD3
:V13 5U4GB
:Clifton
::Doug,
::I have seen this page but it gives me no information about what tubes are in it at all. Just the special hydrogen thyratron. But no numbers. I have searched the internet with google and there is no other information about this model at all that I can find. There is no service data for it in BAMA either. So what would I use it for? Just learning. But I probably wont have it very long. It has too many "droppings" inside. I don't want to touch that. Plus it's huge. I'll give it to someone and he'll tell me what tubes are in it by looking more closely at it.
::Thanks,
::Dave
:::Google "HP 212A" - and this link is at the top of the list: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-02.pdf There are many other links, too. Google is your friend.
:::I'm wondering what you plan to use this thing for?
My cut and paste didn't work right, but perhaps you will be able to sort out the 'V' numbers from the jumble.
Clifton
:Dave,
:Cut and past didn't work right, so try again:
:V1 6X4 V14 0B2
:V2 6L6GB V15 6AU6
:V3 6W4GT V16 HP45
:V10 12AX7
:V11 6AS7G
:V12 OD3
:V13 5U4GB
:Clifton
::Dave,
::Check it out:
::Hewlett Packard 212A Pulse Generator – Tube Compliment
::V1 6X4 V14 0B2
::V2 6L6GB V15 6AU6
::V3 6W4GT V16 HP45
::V4 0B2 V17A,B 6AS7G
::V5 N/A V18 thru 100 N/A
::V6 HP45 V101 thru V109 12AU7, 5963, OR 7316
::V7,8,9 6J6 N/A = not assigned
::V10 12AX7
::V11 6AS7G
::V12 OD3
::V13 5U4GB
::Clifton
:::Doug,
:::I have seen this page but it gives me no information about what tubes are in it at all. Just the special hydrogen thyratron. But no numbers. I have searched the internet with google and there is no other information about this model at all that I can find. There is no service data for it in BAMA either. So what would I use it for? Just learning. But I probably wont have it very long. It has too many "droppings" inside. I don't want to touch that. Plus it's huge. I'll give it to someone and he'll tell me what tubes are in it by looking more closely at it.
:::Thanks,
:::Dave
::::Google "HP 212A" - and this link is at the top of the list: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-02.pdf There are many other links, too. Google is your friend.
::::I'm wondering what you plan to use this thing for?
It has too many "droppings" inside. Initially thinking of "Meeces Pieces" inside on that statement . . . . but certainly it must have been layered sheets opon sheets of Albatross droppings . . . . as you certainly could have seen the silk screened symbolization of all tubes "Vee" numbers and their types. |
HP SCHEMATICS: ![]() ![]() |
:Dave,
:My cut and paste didn't work right, but perhaps you will be able to sort out the 'V' numbers from the jumble.
:Clifton
::Dave,
::Cut and past didn't work right, so try again:
::V1 6X4 V14 0B2
::V2 6L6GB V15 6AU6
::V3 6W4GT V16 HP45
::V10 12AX7
::V11 6AS7G
::V12 OD3
::V13 5U4GB
::Clifton
:::Dave,
:::Check it out:
:::Hewlett Packard 212A Pulse Generator – Tube Compliment
:::V1 6X4 V14 0B2
:::V2 6L6GB V15 6AU6
:::V3 6W4GT V16 HP45
:::V4 0B2 V17A,B 6AS7G
:::V5 N/A V18 thru 100 N/A
:::V6 HP45 V101 thru V109 12AU7, 5963, OR 7316
:::V7,8,9 6J6 N/A = not assigned
:::V10 12AX7
:::V11 6AS7G
:::V12 OD3
:::V13 5U4GB
:::Clifton
::::Doug,
::::I have seen this page but it gives me no information about what tubes are in it at all. Just the special hydrogen thyratron. But no numbers. I have searched the internet with google and there is no other information about this model at all that I can find. There is no service data for it in BAMA either. So what would I use it for? Just learning. But I probably wont have it very long. It has too many "droppings" inside. I don't want to touch that. Plus it's huge. I'll give it to someone and he'll tell me what tubes are in it by looking more closely at it.
::::Thanks,
::::Dave
:::::Google "HP 212A" - and this link is at the top of the list: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-02.pdf There are many other links, too. Google is your friend.
:::::I'm wondering what you plan to use this thing for?
:Sir Dave . . . . .
:Used to use one of those way back in the days of radar design, both for a variable drive source for the modulator feeding the magnetron transmitter.
:And then . . . at a very reduced level and being passed thru SEVERAL stages of shaping / deforming / attenuating circuitry to eventually get the simulation of a feeble return echo, to work on the optimization of image enhancememt circuitry that fed into the final CRT display.
:It has too many "droppings" inside.
:Initially thinking of "Meeces Pieces" inside on that statement . . . . but certainly it must have been layered sheets opon sheets of Albatross droppings . . . . as you certainly could have seen the silk screened symbolization of all tubes "Vee" numbers and their types.
:To Wit:
:I additionally placed the 2 schematic parts down BELOW.
: HP SCHEMATICS:
::Dave,
::My cut and paste didn't work right, but perhaps you will be able to sort out the 'V' numbers from the jumble.
::Clifton
:::Dave,
:::Cut and past didn't work right, so try again:
:::V1 6X4 V14 0B2
:::V10 12AX7
:::V11 6AS7G
:::V12 OD3
:::V13 5U4GB
:::Clifton
::::Dave,
::::Check it out:
::::Hewlett Packard 212A Pulse Generator – Tube Compliment
::::V1 6X4 V14 0B2
::::V2 6L6GB V15 6AU6
::::V3 6W4GT V16 HP45
::::V4 0B2 V17A,B 6AS7G
::::V5 N/A V18 thru 100 N/A
::::V6 HP45 V101 thru V109 12AU7, 5963, OR 7316
::::V7,8,9 6J6 N/A = not assigned
::::V10 12AX7
::::V11 6AS7G
::::V12 OD3
::::V13 5U4GB
::::Clifton
:::::Doug,
:::::I have seen this page but it gives me no information about what tubes are in it at all. Just the special hydrogen thyratron. But no numbers. I have searched the internet with google and there is no other information about this model at all that I can find. There is no service data for it in BAMA either. So what would I use it for? Just learning. But I probably wont have it very long. It has too many "droppings" inside. I don't want to touch that. Plus it's huge. I'll give it to someone and he'll tell me what tubes are in it by looking more closely at it.
:::::Thanks,
:::::Dave
::::::Google "HP 212A" - and this link is at the top of the list: http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-02.pdf There are many other links, too. Google is your friend.
::::::I'm wondering what you plan to use this thing for?
:Sir Dave . . . . .
:To Wit:
: HP SCHEMATICS:
::Dave,
::Clifton
:::Dave,
:::V1 6X4 V14 0B2
:::V10 12AX7
:::V11 6AS7G
:::V12 OD3
:::V13 5U4GB
:::Clifton
::::Dave,
::::Check it out:
::::V1 6X4 V14 0B2
::::V10 12AX7
::::V11 6AS7G
::::V12 OD3
::::V13 5U4GB
::::Clifton
:::::Doug,
:::::Thanks,
:::::Dave
