http://www.youtube.com/watch?v=V5Upb2yAIeE
http://www.youtube.com/watch?v=asf5zVOUzjA
I don't have the Sams on that one, but you must first determine if the buzzing is internal or external to the radio; first, remove the antenna. If the buzzing is still there (and at the same level), the source is internal. Since the radio was working, look for bad connections; this could be almost anywhere, from the power supply to the RF section. It could be a silver mica cap problem in the IF transformers; they will need to be dismantled and the caps replaced.
Johnnysan-
You can always check your environment for RF interference with an AC/battery operated radio, line interference on the AC and RF interference with the battery.
:I can't believe I kept forgetting to try that. I hooked the 55x15 loop antenna to my home theater receiver's AM antenna terminals, and I got zero noise. So I moved the antenna back to the 55x15 and now it's back to being buzz free. I guess I'll just have to wait til the buzzing comes back and then try my home theater again to see if it's environmental or something intermittent in the radio. And I thought the complete rebuild was going to be the hardest part... Thanks for the advice!
Try wiggling or tapping the antenna wire when it happens or when it is quiet?
