EMC tube tester
4/21/2011 10:07:08 PMDale
Hello, I have aquired a tube tester EMC model 204 and the roll chart has some information missing, does annyone know where I could find, I have done a google search and have found nothing, as far as I can see it is identical to a model 205 so same chart would be ok.
Thanx,
Dale
4/22/2011 7:55:50 PMJohnnysan
:Hello, I have aquired a tube tester EMC model 204 and the roll chart has some information missing, does annyone know where I could find, I have done a google search and have found nothing, as far as I can see it is identical to a model 205 so same chart would be ok.
:Thanx,
:Dale
The BAMA site has information for the 203 and 211; it might work on your 204.
Johnnysan-
4/23/2011 3:04:40 PMDale
::Hello, I have aquired a tube tester EMC model 204 and the roll chart has some information missing, does annyone know where I could find, I have done a google search and have found nothing, as far as I can see it is identical to a model 205 so same chart would be ok.
::Thanx,
::Dale
:The BAMA site has information for the 203 and 211; it might work on your 204.
:Johnnysan-
:Hi, there are 3 models that are the same, 203, 204 and 205 are basically identical, also that site did not work, got to the file but got a server error, will try later. In doing some more digging, I also found out that similar testers have the same charts like the Eico 625, only some of the switch positions are letters instead of numbers.
Dale
