Set up for 2A5 with filament at 6.3 volts. You could also use the setting for a #41 which is similar.
: Could someone tell me what the settings should be for testing a # 42 tube on my Hickok 532? The scroll on mine does not list it.
: Set up for 2A5 with filament at 6.3 volts. You could also use the setting for a #41 which is similar.
: Norm
: : Could someone tell me what the settings should be for testing a # 42 tube on my Hickok 532? The scroll on mine does not list it.
: I must need a better scroll as the one I have list neither of the two you suggested!?
: : Hi Charles
: : Set up for 2A5 with filament at 6.3 volts. You could also use the setting for a #41 which is similar.
: : Norm
: : : Could someone tell me what the settings should be for testing a # 42 tube on my Hickok 532? The scroll on mine does not list it.
: Norm
: : I must need a better scroll as the one I have list neither of the two you suggested!?
: : : Hi Charles
: : : Set up for 2A5 with filament at 6.3 volts. You could also use the setting for a #41 which is similar.
: : : Norm
: : : : Could someone tell me what the settings should be for testing a # 42 tube on my Hickok 532? The scroll on mine does not list it.
You could always make a simple adapter from 6F6 to 42 tube.
: Please bear with me. Will this require me to make jumpers from the socket to the tube?
: Charles
: : Here is another way. Set up your tube tester for 6F6. Number 42 is the same with a different base. Here are the differences: Plate #2, Grid #3, Screen #4, Cathode #5, Suppressor #0. These are identified on 539. Hope 532 is marked.
: : Norm
: : : I must need a better scroll as the one I have list neither of the two you suggested!?
: : : : Hi Charles
: : : : Set up for 2A5 with filament at 6.3 volts. You could also use the setting for a #41 which is similar.
: : : : Norm
: : : : : Could someone tell me what the settings should be for testing a # 42 tube on my Hickok 532? The scroll on mine does not list it.
: Norm
: : : Hi Charles
: : : Norm
: Norm
: : : Hi Charles
: : : Norm
: Norm
: : : Hi Charles
: : : Norm
: Norm
: : : Hi Charles
: : : Norm
: Norm
: : : Hi Charles
: : : Norm
: Norm
: : : Hi Charles
: : : Norm
: Hi Charles
: Norm
