4/10/2011 5:11:12 PMElton(94654:0)
Well I hooked up the power supply to the radio, flipped the switch, and I got a hum a bad hum, and monitoring the voltage the 308 supply drops to about 150, and the 144 supply is at 50, checked the field coil and is OK, I also changed out the .5 caps with .47's but heres the thing, the hum and the voltage drop disapaers when I disconnect the .5 from the 144 line, but then no sound at all when the caps are hooked back up to ground they read a dead short??? the caps show no leakage on my vom ...they could be bad but were new out of the package and I don't have anymore .47 could I sub something else just to check ?
4/10/2011 5:30:40 PMElton(94655:94654)
:Well I hooked up the power supply to the radio, flipped the switch, and I got a hum a bad hum, and monitoring the voltage the 308 supply drops to about 150, and the 144 supply is at 50, checked the field coil and is OK, I also changed out the .5 caps with .47's but heres the thing, the hum and the voltage drop disapaers when I disconnect the .5 from the 144 line, but then no sound at all when the caps are hooked back up to ground they read a dead short??? the caps show no leakage on my vom ...they could be bad but were new out of the package and I don't have anymore .47 could I sub something else just to check ?
:Thanks
oops correction when I disconnect the caps from the cathodes of the 27 tubes the hum goes away and the voltage returns to normal, could it be a bad tube?
4/10/2011 6:03:31 PMElton (94656:94655)
::Well I hooked up the power supply to the radio, flipped the switch, and I got a hum a bad hum, and monitoring the voltage the 308 supply drops to about 150, and the 144 supply is at 50, checked the field coil and is OK, I also changed out the .5 caps with .47's but heres the thing, the hum and the voltage drop disapaers when I disconnect the .5 from the 144 line, but then no sound at all when the caps are hooked back up to ground they read a dead short??? the caps show no leakage on my vom ...they could be bad but were new out of the package and I don't have anymore .47 could I sub something else just to check ?
::Thanks
:oops correction when I disconnect the caps from the cathodes of the 27 tubes the hum goes away and the voltage returns to normal, could it be a bad tube?
Well solved my own problem it was a bad brand new cap!
radio working now.
4/10/2011 6:40:56 PMSteve S(94664:94656)
Don't ya just hate it when that happens? Just goes to show that brand new parts can't be trusted 100% of the time. Doesn't happen too often, but enough times to justify double checking.
S
4/10/2011 7:16:58 PMMarv Nuce(94667:94664)
Steve,
Right, not often, but has happened to me a couple times. Upon delivery, I always inventory for correct order, and at the same time measure every cap for correct value.
:Don't ya just hate it when that happens? Just goes to show that brand new parts can't be trusted 100% of the time. Doesn't happen too often, but enough times to justify double checking.
:S
