Capehart Farnsworth 35P7
4/2/2011 1:40:03 PMPaul Knaack
Hello, Would anyone have a schematic and alignment instructions for this set. It is in set 135, folder 4 of Sams photofact. Thanks, Paul
4/2/2011 6:21:05 PMJohnnysan
:Hello, Would anyone have a schematic and alignment instructions for this set. It is in set 135, folder 4 of Sams photofact. Thanks, Paul
I will scan it and email it to you soon.
Johnnysan-
4/2/2011 6:24:37 PMEdd
Sir Paul. . . . .
Seems like the master schematic of this was shrunk to fit on an 8.5 by 17 page instead of their usual procedure of breaking
that size of a schema up into 2-3 pages.
Therefore I had quite a small copy to begin with . . . but enhanced it on up, as well as it would sharpen and clean up.
Now just pull up the info and put on some side music of "My Sharona" and you will be in business.
Two attachments beeeeee-low . . . .
Le Schematique:
Alignment:
4/2/2011 9:34:12 PMPaul Knaack
:Thanks Edd and Johnnysan, After recapping I only had plate voltage to one 6v6. Half of the primary of the output transformer was open. I replaced the output transformer with a Hammond 125D that I had on hand (it is rated at 10 watts) Is this too low for the p-p 6v6?
I'm thinking it is, although it is working pretty good.
Thanks again, Paul
: Le Schematique:
: Alignment:
