Antique Electronics Company (www.tubesandmore.com) has a universal replacement transformer P-T291 listed for $17 USD rated at 8 Watts. I think the primary impedance is 4K to 10K Ohms and secondary impedance of 4 to 16 Ohms I think. You can check it out on their web site.
Clifton
:Just discovered this awesome site...had no idea that others had a love for old radios!
:Anyhow this audio output crosses to a ton of transformers but I need pri. 7000ohm w/center tap and sec. 4ohm impedance. It should measure about 260 ohms DC resistance.
:Willing to pay a reasonable price...used is fine.
:Application is dual 6V6 outputs.
That should be Antique Electronics Supply...
Clifton
::Just discovered this awesome site...had no idea that others had a love for old radios!
::Anyhow this audio output crosses to a ton of transformers but I need pri. 7000ohm w/center tap and sec. 4ohm impedance. It should measure about 260 ohms DC resistance.
::Willing to pay a reasonable price...used is fine.
::Application is dual 6V6 outputs.
Looks like I owe you again, Clifton...thanks for the info.
:That should be Antique Electronics Supply...
:Clifton
:::Just discovered this awesome site...had no idea that others had a love for old radios!
:::Anyhow this audio output crosses to a ton of transformers but I need pri. 7000ohm w/center tap and sec. 4ohm impedance. It should measure about 260 ohms DC resistance.
:::Willing to pay a reasonable price...used is fine.
:::Application is dual 6V6 outputs.
