Zenith 6-S-152 Transformer
3/30/2011 8:18:18 AMDave F
I need to replace my transformer on this 1937 Zenith console. It has # C95-289-N stamped on it. but when I went to order it from a supplier they wanted the impedence, SP,PP and wattage, does anyone know what those would be on this transformer, and any recommmended sources to find one reasonably priced?
3/30/2011 10:39:38 AMClifton
Dave F,
You might try a 'universal output' transformer. It has taps for several different input impedances and output impedances. Antique Electronics Supply (www.tubesandmore.com) has the P-T291 rated at 8 Watts for around $17. You can try different primary and secondary tap combinations that sound best with your speaker.
Clifton
:I need to replace my transformer on this 1937 Zenith console. It has # C95-289-N stamped on it. but when I went to order it from a supplier they wanted the impedence, SP,PP and wattage, does anyone know what those would be on this transformer, and any recommmended sources to find one reasonably priced?
3/30/2011 12:06:21 PMLewis L
:Dave F,
:You might try a 'universal output' transformer. It has taps for several different input impedances and output impedances. Antique Electronics Supply (www.tubesandmore.com) has the P-T291 rated at 8 Watts for around $17. You can try different primary and secondary tap combinations that sound best with your speaker.
:Clifton
::I need to replace my transformer on this 1937 Zenith console. It has # C95-289-N stamped on it. but when I went to order it from a supplier they wanted the impedence, SP,PP and wattage, does anyone know what those would be on this transformer, and any recommmended sources to find one reasonably priced?
There is a site that gives the impedeance of output tubes, and you can find it with Google. Also has a good tutorial. Google "Output transformers" and you can find it. Very useful.
3/30/2011 12:47:57 PMClifton
Lewis L,
http://www.radioremembered.org/ and click on restoration/troubleshooting...
Clifton
::Dave F,
::You might try a 'universal output' transformer. It has taps for several different input impedances and output impedances. Antique Electronics Supply (www.tubesandmore.com) has the P-T291 rated at 8 Watts for around $17. You can try different primary and secondary tap combinations that sound best with your speaker.
::Clifton
:::I need to replace my transformer on this 1937 Zenith console. It has # C95-289-N stamped on it. but when I went to order it from a supplier they wanted the impedence, SP,PP and wattage, does anyone know what those would be on this transformer, and any recommmended sources to find one reasonably priced?
:There is a site that gives the impedeance of output tubes, and you can find it with Google. Also has a good tutorial. Google "Output transformers" and you can find it. Very useful.
:Lewis
3/31/2011 9:46:31 AMDaveF
:Lewis L,
:http://www.radioremembered.org/ and click on restoration/troubleshooting...
:Clifton
:::Dave F,
:::You might try a 'universal output' transformer. It has taps for several different input impedances and output impedances. Antique Electronics Supply (www.tubesandmore.com) has the P-T291 rated at 8 Watts for around $17. You can try different primary and secondary tap combinations that sound best with your speaker.
:::Clifton
::::I need to replace my transformer on this 1937 Zenith console. It has # C95-289-N stamped on it. but when I went to order it from a supplier they wanted the impedence, SP,PP and wattage, does anyone know what those would be on this transformer, and any recommmended sources to find one reasonably priced?
::There is a site that gives the impedeance of output tubes, and you can find it with Google. Also has a good tutorial. Google "Output transformers" and you can find it. Very useful.
::Lewis
I see a junk chassis on a 10-s-147 on Ebay, would you know if the power transformers would be compatible?
