Coronado 675 Cap ID
3/27/2011 6:29:23 PMBob E
I have removed a cap that connects to chassis ground and one side of the antenna choke coil. I believe this
cap is C19 on the schematic. It has a value of .01 uuf.
The part removed is "wax" Sealdtite paper capacitor and has the value in red ink on the brown outer cover that says I think 100-18K. I am asking what size modern replace cap do I use here? The double u in the .01 uuf and the 18 K is not clear to me as to what to use as a replacement. Thanks,Bob
3/27/2011 7:03:10 PMJohnnysan
:I have removed a cap that connects to chassis ground and one side of the antenna choke coil. I believe this
:cap is C19 on the schematic. It has a value of .01 uuf.
:The part removed is "wax" Sealdtite paper capacitor and has the value in red ink on the brown outer cover that says I think 100-18K. I am asking what size modern replace cap do I use here? The double u in the .01 uuf and the 18 K is not clear to me as to what to use as a replacement. Thanks,Bob
That would be a misprint in Riders; there is no .01uuf. It would have to be .01uf.
Johnnysan
3/27/2011 7:15:49 PMNorm Leal
Hi Bob
Can you measure the part? I wouldn't replace this cap unless it's known to be bad. Doubt it's a .01 mf and .01 mmf doesn't make sense.
http://www.nostalgiaair.org/PagesByModel/105/M0007105.pdf
Since this cap is across a coil in the antenna circuit .01 mf is too large. No such thing as .01 mmf in a radio. This would be like two pieces of wire being close together.
::I have removed a cap that connects to chassis ground and one side of the antenna choke coil. I believe this
::cap is C19 on the schematic. It has a value of .01 uuf.
::The part removed is "wax" Sealdtite paper capacitor and has the value in red ink on the brown outer cover that says I think 100-18K. I am asking what size modern replace cap do I use here? The double u in the .01 uuf and the 18 K is not clear to me as to what to use as a replacement. Thanks,Bob
:That would be a misprint in Riders; there is no .01uuf. It would have to be .01uf.
:Johnnysan
3/27/2011 8:16:58 PMPictures posted to Photobucket
Does this help at all?
http://s231.photobucket.com/albums/ee203/bobwiththeradioproblem/?start=all
3/27/2011 8:19:25 PMBob E
Removed from the circuit,as is, it tests .o2uf
:Hi Bob
: Can you measure the part? I wouldn't replace this cap unless it's known to be bad. Doubt it's a .01 mf and .01 mmf doesn't make sense.
:http://www.nostalgiaair.org/PagesByModel/105/M0007105.pdf
: Since this cap is across a coil in the antenna circuit .01 mf is too large. No such thing as .01 mmf in a radio. This would be like two pieces of wire being close together.
:::I have removed a cap that connects to chassis ground and one side of the antenna choke coil. I believe this
:::cap is C19 on the schematic. It has a value of .01 uuf.
:::The part removed is "wax" Sealdtite paper capacitor and has the value in red ink on the brown outer cover that says I think 100-18K. I am asking what size modern replace cap do I use here? The double u in the .01 uuf and the 18 K is not clear to me as to what to use as a replacement. Thanks,Bob
::That would be a misprint in Riders; there is no .01uuf. It would have to be .01uf.
::Johnnysan
3/27/2011 8:43:36 PMNorm Leal
Sure looks like a .01 or .02 mf. If that's the case you don't need the antenna coil across this cap. The coil is effectively shorted out by this cap. Could be replaced by a piece of wire.
A .01 mf cap at RF frequencies acts just about as a short. Maybe it has an 18K resistor in series with the cap?
:Removed from the circuit,as is, it tests .o2uf
::Hi Bob
:: Can you measure the part? I wouldn't replace this cap unless it's known to be bad. Doubt it's a .01 mf and .01 mmf doesn't make sense.
::http://www.nostalgiaair.org/PagesByModel/105/M0007105.pdf
:: Since this cap is across a coil in the antenna circuit .01 mf is too large. No such thing as .01 mmf in a radio. This would be like two pieces of wire being close together.
::::I have removed a cap that connects to chassis ground and one side of the antenna choke coil. I believe this
::::cap is C19 on the schematic. It has a value of .01 uuf.
::::The part removed is "wax" Sealdtite paper capacitor and has the value in red ink on the brown outer cover that says I think 100-18K. I am asking what size modern replace cap do I use here? The double u in the .01 uuf and the 18 K is not clear to me as to what to use as a replacement. Thanks,Bob
:::That would be a misprint in Riders; there is no .01uuf. It would have to be .01uf.
:::Johnnysan
