:There is a voltage pin out chart on the schematic. You do need to check for B+ .. Use a VOM from B- and test for the voltage listed.
Once you get the hang of things, you'll find that most sets are quite conventional in design, and that there is a straight-forward methodical approach to troubleshooting a radio from one end to the other, but they can still be a nightmare when you run into things like water damage. My Philco 60 was soaked in a flood, which is how I was able to find it at the curbside. This destroyed the power transformer (and the cabinet). The oscillator coil opened up, but this seems to be a common problem even without water damage. The output transformer was also open, but the tone capacitor was shorted, and may have been the cause. Luckily I was able to salvage all of the other coils, including the field coil, and, as luck would have it, a larger, but still capable of mounting, power transformer was for sale at American Science and Surplus for only $9.50. It works great without even getting warm!
On the other hand, when referring to 'open' resistors, I was, in fact, referring to resistors whose electrical circuit had opened.
