Rebuilt Radio - Noise
3/16/2011 8:22:23 PMChris
I recently finished a complete rebuild of a Motorola 55x15 AM radio. Every single resistor, capacitor, etc.. has been replaced. Even the silver-mica caps in the IFT cans were cut out and replaced. I haven't yet calibrated it, but I will be soon.
Before I do, I'd like to know if anyone can identify the noise this radio is making, and whether or not it will go away after calibration, or if further repair is needed. It's a buzzing sound that is present through most of the band.
I can only receive 1 or 2 stations at present, and they're usually affected by this buzz. I've included a link to a youtube video with the noise. Any help is GREATLY appreciated.
http://www.youtube.com/watch?v=KbAGJOlH7Yc
3/16/2011 8:34:37 PMNorm Leal
Hi Chris
Outside interference which may be from fluorescent lights, computer etc.
:I recently finished a complete rebuild of a Motorola 55x15 AM radio. Every single resistor, capacitor, etc.. has been replaced. Even the silver-mica caps in the IFT cans were cut out and replaced. I haven't yet calibrated it, but I will be soon.
:Before I do, I'd like to know if anyone can identify the noise this radio is making, and whether or not it will go away after calibration, or if further repair is needed. It's a buzzing sound that is present through most of the band.
:I can only receive 1 or 2 stations at present, and they're usually affected by this buzz. I've included a link to a youtube video with the noise. Any help is GREATLY appreciated.
:http://www.youtube.com/watch?v=KbAGJOlH7Yc
3/16/2011 8:34:54 PMBob Z
Your url comes up as 'unwatchable' as it can only be view via a link from youtube. Check you permission on youtube.
3/16/2011 8:59:28 PMChris
I have the video unlisted but it should be accessible from the link. It checks out okay on my end (with me logged out of youtube). Thanks for looking!
3/16/2011 8:48:14 PMWarren
Check the loop antenna for continuity and that it's connected correct. This one must have the return to the AVC line. Or it will buzz and be in-sensitive like it is.
3/16/2011 8:58:01 PMChris
Warren, the antenna checks out for continuity, and it's hooked up exactly as it was before the rebuild. Any other suggestions? Thanks!
3/16/2011 9:33:18 PMSteve S
Change location and see if you experience the same thing. Also see if another AM radio picks up the same interference where you presently hear it.
Steve
3/16/2011 9:24:07 PMMarv Nuce
Chris,
Sounds like the interference I've heard from flourescent lights (60 hz), but could be from a lot of sources. Computers, dimmers.
3/16/2011 9:40:13 PMChris
I set it up in a room away from electronics and the wall. The lights were off (as I'm sure you could tell). I'm starting to wonder if I did something during my repair that could be causing this. I bundled a fair number of the wires together and zip tied them for cleanliness, is crosstalk a possibility?
3/16/2011 11:05:07 PMdale
:I set it up in a room away from electronics and the wall. The lights were off (as I'm sure you could tell). I'm starting to wonder if I did something during my repair that could be causing this. I bundled a fair number of the wires together and zip tied them for cleanliness, is crosstalk a possibility?
I beleive Warren had mentioned that any ac carrying wires should be carefully kept away from IF and RF signal wires, could be something to try.
