models 89 and 19 radio
3/16/2011 3:33:49 PMbobby stepp
sorry i didn't give all info onfilter cond.im refrrring to part 7 on schematic the condenser are.o9
and .o9 and .25 and .o5 and .o5 the ,25 is grounded to can .can i use regular caps.can i twist all grd.together and solder to can what about .25 do i still grd. it to can what can i use for .09 im dumd when it comes to caps. thanks vert much.appreciate all information.
3/16/2011 5:59:19 PMGeorge
Bobby ALL are grounded to can....Just make sure can is grounded to chassis...For the .09 you can twist 3 .033 together + to + and - to - to make up one .09..I have done a dozen of these cans and stuffed all back into can and used heat shrink to cover my connections. I also wrote on underside of chassis with a perm. marker so future restorers know what I did..
: sorry i didn't give all info onfilter cond.im refrrring to part 7 on schematic the condenser are.o9
:and .o9 and .25 and .o5 and .o5 the ,25 is grounded to can .can i use regular caps.can i twist all grd.together and solder to can what about .25 do i still grd. it to can what can i use for .09 im dumd when it comes to caps. thanks vert much.appreciate all information.
3/16/2011 6:06:17 PMGeorge ..oops
:Bobby ALL are grounded to can....Just make sure can is grounded to chassis...For the .09 you can twist 3 .033 together + to + and - to - to make up one .09..I have done a dozen of these cans and stuffed all back into can and used heat shrink to cover my connections. I also wrote on underside of chassis with a perm. marker so future restorers know what I did..
OR YOU CAN USE A .1 to replace each of the .09
:: sorry i didn't give all info onfilter cond.im refrrring to part 7 on schematic the condenser are.o9
::and .o9 and .25 and .o5 and .o5 the ,25 is grounded to can .can i use regular caps.can i twist all grd.together and solder to can what about .25 do i still grd. it to can what can i use for .09 im dumd when it comes to caps. thanks vert much.appreciate all information.
3/16/2011 11:11:55 PMplanigan
Bobby, those are not electrolytics so no polarity involved. You can use any modern cap at right mfd and voltage rating. The only problem I see is which cap goes to where. schematic shows 5x #7 caps connected but does not give there value but all go to ground. PL
::Bobby ALL are grounded to can....Just make sure can is grounded to chassis...For the .09 you can twist 3 .033 together + to + and - to - to make up one .09..I have done a dozen of these cans and stuffed all back into can and used heat shrink to cover my connections. I also wrote on underside of chassis with a perm. marker so future restorers know what I did..
:OR YOU CAN USE A .1 to replace each of the .09
::: sorry i didn't give all info onfilter cond.im refrrring to part 7 on schematic the condenser are.o9
:::and .o9 and .25 and .o5 and .o5 the ,25 is grounded to can .can i use regular caps.can i twist all grd.together and solder to can what about .25 do i still grd. it to can what can i use for .09 im dumd when it comes to caps. thanks vert much.appreciate all information.
