What I would do is get a "pencil" style signal injector, start at the output transistors and work your way back to the preamp stage until you can be certain which right channel audio stage is the real problem. And put a magnifying glass to the circuit board and look for hairline cracks and suspect solder joints. Don't forget to check all of the "ground" connections. Depending on your loudspeaker arrangement while much less likely, there might even be a problem with a crossover network.
:Hello,
: I am trying to solve a problem with my radio. I have replaced all the electro caps in the radio (91bfm2) and the multiplex (91famp-11). All things work except that the volume out of the right channel speakers(multiplex) is very low when output on ds-501 set at 1.5v. I can get good volume if I over adjust output to 2+ volts but any increase in speaker volume produces very scratchy sound. all other transistor voltages seem normal. Anybody else had this problem? Thanks
Scott,
DS-501 is a PNP Germanium transistor. When you replaced “ALL” of the electrolytic capacitors; did you check or replace the small 10mfd coupling cap on the base of the DS-66 Pre-driver transistor in the multiplex unit? Double check your testing hook up on the bench. With all the back and forth cabling and faders on this set-up, it’s very easy to get something hooked up wrong on the bench.
Are you working from the Sams schematic or the Delco service literature?
Meade
Regardless of the statement in the link that Delco came out with a silicon DS-501, I maintain that the DS-501 transistor as used in Delco auto radios is PNP germanium. Delco service literature and the NTE cross reference guide both agree on germanium. NTE recommended replacement for DS-501 is NTE 105 (PNP-Ge, Audio Power Amp, case style: TO-36)
Meade
Clifton
::http://semiconductormuseum.com/Transistors/LectureHall/JoeKnight/JoeKnight_EarlyPowerTransistorHistory_Delco_Page2.htm
:Regardless of the statement in the link that Delco came out with a silicon DS-501, I maintain that the DS-501 transistor as used in Delco auto radios is PNP germanium. Delco service literature and the NTE cross reference guide both agree on germanium. NTE recommended replacement for DS-501 is NTE 105 (PNP-Ge, Audio Power Amp, case style: TO-36)
:Meade
