I've had good luck cleaning up airplane dials but this is my first time with a 1947 slide rule dial and it looks fragile so I don't want to mess up.
What can I use to 'restore' it without damaging the paint?
:I used mild soap and water but the dial still has a discolored film and what looks like grease spots. The paint looks and feels like it was applied to the outside of the glass rather than the inside.
:I've had good luck cleaning up airplane dials but this is my first time with a 1947 slide rule dial and it looks fragile so I don't want to mess up.
:What can I use to 'restore' it without damaging the paint?
:Daniel,
:First thing is to scan it 1 to 1, before any further wash jobs, so you have a copy of the original, in case you have to reproduce it by whatever means. I've been successful using Adobe, MS Visio, and clear waterslide decals to reproduce a couple.
:marv
::I used mild soap and water but the dial still has a discolored film and what looks like grease spots. The paint looks and feels like it was applied to the outside of the glass rather than the inside.
::I've had good luck cleaning up airplane dials but this is my first time with a 1947 slide rule dial and it looks fragile so I don't want to mess up.
::What can I use to 'restore' it without damaging the paint?
:I have a question about decals. First of all do you invert left to right before printing them so the decal will be on the inside (rather than the outside) of the glass/plexiglass replacement dial, and secondly, is common plexiglass good for slide on decals?
::Daniel,
::First thing is to scan it 1 to 1, before any further wash jobs, so you have a copy of the original, in case you have to reproduce it by whatever means. I've been successful using Adobe, MS Visio, and clear waterslide decals to reproduce a couple.
::marv
:::I used mild soap and water but the dial still has a discolored film and what looks like grease spots. The paint looks and feels like it was applied to the outside of the glass rather than the inside.
:::I've had good luck cleaning up airplane dials but this is my first time with a 1947 slide rule dial and it looks fragile so I don't want to mess up.
:::What can I use to 'restore' it without damaging the paint?
Marv, you are so right. I always keep the flatbed scanner warm whenever I start working on a dial face - you just never know.
:Thanks everyone for the interest and suggestions.
:Marv, you are so right. I always keep the flatbed scanner warm whenever I start working on a dial face - you just never know.
