If the tubes test good and don't show any shorts on the tester, and the Voltages look OK in the radio, I wouldn't worry about a little blue glow. You might touch the power transformer a few times to ensure it is not running too hot.
P. S. If it is battery operated. I am assuming there is a battery eliminator used?
You mention Blue rather trhan a purple color. If the blue is seen just inside the glass not a problem. If there is a purple color within elements a tube is gassy.
A gassy tube can get worse over time. It can run away drawing current.
:I forgot to mention also that the radio is only pulling less than an amp. It's rated at 145W but I only measured 120W which I guess is good. I have a 1.5A fuse in line also. If that tube was bad wouldn't it start drawing more current? It got me thinking when you mentioned the heated transformer.
:Steve
: You mention Blue rather trhan a purple color. If the blue is seen just inside the glass not a problem. If there is a purple color within elements a tube is gassy.
: A gassy tube can get worse over time. It can run away drawing current.
::I forgot to mention also that the radio is only pulling less than an amp. It's rated at 145W but I only measured 120W which I guess is good. I have a 1.5A fuse in line also. If that tube was bad wouldn't it start drawing more current? It got me thinking when you mentioned the heated transformer.
the radio stations where I worked in my early days had mercury vapor rectifiers. The 5kW guys had six 8008s that flashed merrily with the modulation. Fun to watch.
::Steve
:: You mention Blue rather trhan a purple color. If the blue is seen just inside the glass not a problem. If there is a purple color within elements a tube is gassy.
:: A gassy tube can get worse over time. It can run away drawing current.
:::I forgot to mention also that the radio is only pulling less than an amp. It's rated at 145W but I only measured 120W which I guess is good. I have a 1.5A fuse in line also. If that tube was bad wouldn't it start drawing more current? It got me thinking when you mentioned the heated transformer.
::Steve
If the glow is a purple haze in the tube (usually purple, but sometimes other colors), then this is gas. Gassy tubes can function well, but can run away with current.
:If the glow is on the glass or on the mica, or even on the metal elements (most likely plate, possibly on the inside, with a shadow of the grids present), this is normal cathode ray glow. Some have said that it's a reaction to impurities in the glass, etc., but since I have also seen it on mica and on the elements themselves, that leads me to believe that it is not due to the glass alone. This type of glow is no cause for concern.
:If the glow is a purple haze in the tube (usually purple, but sometimes other colors), then this is gas. Gassy tubes can function well, but can run away with current.
All the Best,
Bill
I have a couple of G45 tubes in use in my Majestic 181 that exhibit this glow. It is definitely a faint fog, and is from gas. It came when I baked the tubes in the oven to increase their emission. The emission may have in fact increased due to this gas release. However, it is slight, and the increased emission is semi-permanent, and the tubes play well, so I just keep using them.
A deeper blue glow that is definitely on the surface of parts within the tube or the glass is, however, not caused by gas, and is of no concern.
:All tubes are time bombs. If you have a gassy tube which hasn't been fired up in decades, it may heal itself after a couple of days of continuous usage under load, but will probably not last all that much longer. If you have a really nice radio that you want to listen to and keep, replace the tube, they're cheap enough.
