A wiring diagram is in Rider but didn't see a schematic.
http://www.nostalgiaair.org/PagesByModel/799/M0039799.pdf
:Wondering if anyone has info on a Fada 6 R60 TRF set, can't seem to find any info in my schematics.
:thanks Martin.......
Can anyone fill in the blanks for me as far as the voltages for the R60
+B PWR 90V?
+B RAD
+B DET
-C AUD
-C PWR
+A 5VDC ?
:Martin
: A wiring diagram is in Rider but didn't see a schematic.
:http://www.nostalgiaair.org/PagesByModel/799/M0039799.pdf
::Wondering if anyone has info on a Fada 6 R60 TRF set, can't seem to find any info in my schematics.
::thanks Martin.......
B+ power can be 90 or 135 volts. If your output tube is 01A use -4.5 volts for the C supply and 90 volts. If output tube is 71A you can use 90 or 135 volts for B+ power and - 22 1/2 volts for C-. C- for audio stage will be - 4 1/2 volts.
Radio B+ can be 67 1/2 or 90 volts.
Detector B+ is best at 22 1/2 volts.
You should have 5 volts on tube filaments. The radio has rheostats to reduce A voltage so best to start off with 5.5 or 6 volts. During 1920's a 6 volt car battery was used.
:Can anyone fill in the blanks for me as far as the voltages for the R60
:+B PWR 90V?
:+B RAD
:+B DET
:-C AUD
:-C PWR
:+A 5VDC ?
::Martin
:: A wiring diagram is in Rider but didn't see a schematic.
::http://www.nostalgiaair.org/PagesByModel/799/M0039799.pdf
:::Wondering if anyone has info on a Fada 6 R60 TRF set, can't seem to find any info in my schematics.
:::thanks Martin.......
:Martin
: B+ power can be 90 or 135 volts. If your output tube is 01A use -4.5 volts for the C supply and 90 volts. If output tube is 71A you can use 90 or 135 volts for B+ power and - 22 1/2 volts for C-. C- for audio stage will be - 4 1/2 volts.
: Radio B+ can be 67 1/2 or 90 volts.
: Detector B+ is best at 22 1/2 volts.
: You should have 5 volts on tube filaments. The radio has rheostats to reduce A voltage so best to start off with 5.5 or 6 volts. During 1920's a 6 volt car battery was used.
::Can anyone fill in the blanks for me as far as the voltages for the R60
::+B PWR 90V?
::+B RAD
::+B DET
::-C AUD
::-C PWR
::+A 5VDC ?
:::Martin
::: A wiring diagram is in Rider but didn't see a schematic.
:::http://www.nostalgiaair.org/PagesByModel/799/M0039799.pdf
::::Wondering if anyone has info on a Fada 6 R60 TRF set, can't seem to find any info in my schematics.
::::thanks Martin.......
