dayfan five radio impedance device ciols
3/1/2011 10:23:54 PMdennis lupyon
Hi guys i am workyng on a dayfan 5 radio there are 2 coils under the chassis that are called impedance device.Iwas able to get a reading on one and found it was 600 ohms i cant find a choke listed that high i can only find a choke with 140 to 150 ohms will this work or should i try to re wind the old coils thank you in advance dennis
3/1/2011 10:45:53 PMNorm Leal
Hi Dennis
Your 150 ohm coils will be ok. These impedance coils are RF chokes. You could buy 2.5 mh chokes but your coils will be good enough.
http://www.nostalgiaair.org/PagesByModel/932/M0039932.pdf
:Hi guys i am workyng on a dayfan 5 radio there are 2 coils under the chassis that are called impedance device.Iwas able to get a reading on one and found it was 600 ohms i cant find a choke listed that high i can only find a choke with 140 to 150 ohms will this work or should i try to re wind the old coils thank you in advance dennis
