The DC Set, how can I make batterys?
2/25/2011 8:31:57 PMdave owens.
The B and A batterys. can I use 9v. batterys and how?Also, Ive two sets, did they never plug in to 110v.?
motorola 41d amd emerson dc308. both have no 110v. plug. both seem battery olny, making them portable radios. thank you for any help as now starting the cleanup and powerup.
intrested in stepping down reglaur 120v. steps and making batterys for both units. motorola has 4 lead wires, grn., red, wht., and yel. no batt. terminal or 120v. plug.
emerson has battery plugs, terminal and no 120v. plug.
thank you for seeing this, dave.
2/25/2011 10:54:00 PMdave owens.
:The B and A batterys. can I use 9v. batterys and how?Also, Ive two sets, did they never plug in to 110v.?
:motorola 41d amd emerson dc308. both have no 110v. plug. both seem battery olny, making them portable radios. thank you for any help as now starting the cleanup and powerup.
:intrested in stepping down reglaur 120v. steps and making batterys for both units. motorola has 4 lead wires, grn., red, wht., and yel. no batt. terminal or 120v. plug. I have found that the radio set is Galvin MFG. CO. AND LOOKING At the other model's if I had a 52d this would have battery packs, 2 b batterys and 1 a battery,also, 52d, has a wall plug 120v. showing here model 41d, and 51d,has no wall plug. Is it possiable to steap down standard wall plug for getting the 90v needed to power these model sets?
thtank you for looking at this, dave.
:emerson has battery plugs, terminal and no 120v. plug.
:thank you for seeing this, dave.
2/26/2011 11:46:20 AMTerry Decker
::The B and A batterys. can I use 9v. batterys and how?Also, Ive two sets, did they never plug in to 110v.?
::motorola 41d amd emerson dc308. both have no 110v. plug. both seem battery olny, making them portable radios. thank you for any help as now starting the cleanup and powerup.
::intrested in stepping down reglaur 120v. steps and making batterys for both units. motorola has 4 lead wires, grn., red, wht., and yel. no batt. terminal or 120v. plug. I have found that the radio set is Galvin MFG. CO. AND LOOKING At the other model's if I had a 52d this would have battery packs, 2 b batterys and 1 a battery,also, 52d, has a wall plug 120v. showing here model 41d, and 51d,has no wall plug. Is it possiable to steap down standard wall plug for getting the 90v needed to power these model sets?
:thtank you for looking at this, dave.
::emerson has battery plugs, terminal and no 120v. plug.
::thank you for seeing this, dave.
Antique Electronic Supply has an inexpensive battery eliminator that does a decent job. I'm using one for my Atwater Kent 30.
Terry
2/26/2011 3:40:51 PMdave owens.
:::The B and A batterys. can I use 9v. batterys and how?Also, Ive two sets, did they never plug in to 110v.?
:::motorola 41d amd emerson dc308. both have no 110v. plug. both seem battery olny, making them portable radios. thank you for any help as now starting the cleanup and powerup.
:::intrested in stepping down reglaur 120v. steps and making batterys for both units. motorola has 4 lead wires, grn., red, wht., and yel. no batt. terminal or 120v. plug. I have found that the radio set is Galvin MFG. CO. AND LOOKING At the other model's if I had a 52d this would have battery packs, 2 b batterys and 1 a battery,also, 52d, has a wall plug 120v. showing here model 41d, and 51d,has no wall plug. Is it possiable to steap down standard wall plug for getting the 90v needed to power these model sets?
::thtank you for looking at this, dave.
:::emerson has battery plugs, terminal and no 120v. plug.
:::thank you for seeing this, dave.
:Antique Electronic Supply has an inexpensive battery eliminator that does a decent job. I'm using one for my Atwater Kent 30.
:Terry
2/26/2011 3:41:15 PMdave owens.
::::The B and A batterys. can I use 9v. batterys and how?Also, Ive two sets, did they never plug in to 110v.?
::::motorola 41d amd emerson dc308. both have no 110v. plug. both seem battery olny, making them portable radios. thank you for any help as now starting the cleanup and powerup.
::::intrested in stepping down reglaur 120v. steps and making batterys for both units. motorola has 4 lead wires, grn., red, wht., and yel. no batt. terminal or 120v. plug. I have found that the radio set is Galvin MFG. CO. AND LOOKING At the other model's if I had a 52d this would have battery packs, 2 b batterys and 1 a battery,also, 52d, has a wall plug 120v. showing here model 41d, and 51d,has no wall plug. Is it possiable to steap down standard wall plug for getting the 90v needed to power these model sets?
:::thtank you for looking at this, dave.
::::emerson has battery plugs, terminal and no 120v. plug.
::::thank you for seeing this, dave.
::Antique Electronic Supply has an inexpensive battery eliminator that does a decent job. I'm using one for my Atwater Kent 30.
::Terry
2/26/2011 3:41:45 PMdave owens.
:::::The B and A batterys. can I use 9v. batterys and how?Also, Ive two sets, did they never plug in to 110v.?
:::::motorola 41d amd emerson dc308. both have no 110v. plug. both seem battery olny, making them portable radios. thank you for any help as now starting the cleanup and powerup.
:::::intrested in stepping down reglaur 120v. steps and making batterys for both units. motorola has 4 lead wires, grn., red, wht., and yel. no batt. terminal or 120v. plug. I have found that the radio set is Galvin MFG. CO. AND LOOKING At the other model's if I had a 52d this would have battery packs, 2 b batterys and 1 a battery,also, 52d, has a wall plug 120v. showing here model 41d, and 51d,has no wall plug. Is it possiable to steap down standard wall plug for getting the 90v needed to power these model sets?
::::thtank you for looking at this, dave.
:::::emerson has battery plugs, terminal and no 120v. plug.
:::::thank you for seeing this, dave.
:::Antique Electronic Supply has an inexpensive battery eliminator that does a decent job. I'm using one for my Atwater Kent 30.
:::Terry
2/27/2011 8:05:44 PMdave owens.
:Terry
Thank You Terry, I will look at antique electric supply. And i,m sorry for the postings I made in mistake olny because I am new with posting questions here at the forum. dave owens.
