316 tube..what is it?? GREAT STORY!!!
2/25/2011 2:05:44 AMgeorge
I recently purchased at a local auction a box of tubes. ST, GT, and globe styles (no boxes).. There was over 200 tubes in this box mostly common GT style tubes..At the auction I could not dig all the way to the bottm of the box so took a chance and bought the whole dam thing...for 100.00... Tubes were VERY dirty and coated in grime...That night I carefully took tubes out of box and spread out over my floor...OHHHHH MY GOD..a radio collectors dream..I KID YOU NOT..At bottom of box was 3 250 globes (test good) 3 199s (test good)....4 245 globes (test good) 3 10s (2 test good) and a 316 that tests good... and about 3/4 of the rest all tested good..common GT and some hard to find ST style.. My question is: What exactly is a 316? Is that an early style rectifier same as a 80?
2/25/2011 12:27:52 PMJohn
:I recently purchased at a local auction a box of tubes. ST, GT, and globe styles (no boxes).. There was over 200 tubes in this box mostly common GT style tubes..At the auction I could not dig all the way to the bottm of the box so took a chance and bought the whole dam thing...for 100.00... Tubes were VERY dirty and coated in grime...That night I carefully took tubes out of box and spread out over my floor...OHHHHH MY GOD..a radio collectors dream..I KID YOU NOT..At bottom of box was 3 250 globes (test good) 3 199s (test good)....4 245 globes (test good) 3 10s (2 test good) and a 316 that tests good... and about 3/4 of the rest all tested good..common GT and some hard to find ST style.. My question is: What exactly is a 316? Is that an early style rectifier same as a 80?
George,
Who is the manufacturer of the tube...Cunningham by chance? RCA made a 16 half wave rectifier for a short period of time that was replaced by the 81. Is it an ST shape or globe or like an acorn/door knob? A 316A is a door knob shape and is a triode with four pins. Did you test it as a 16/how did you determine it to be good? Neat & valuable finds, John
2/25/2011 1:25:38 PMRichard
Is the 316 a Western Electric?
2/25/2011 2:08:48 PMLewis Linson
:Is the 316 a Western Electric?
Good point, Richard, but I believe WECo Always had a letter after the three digits.
Leiws
2/25/2011 2:26:32 PMRichard
Lewis, to the best of my knowledge they always had a letter. Having said that, I have an engraved base Western Electric 300, that is clearly identical in appearance to the 300A/B, but has no letter engraved after the 300.
Richard
2/25/2011 3:24:05 PMGeorge.... AND>>>>> ALSO
The tube is a 316 Cunningham not sure what it is used in...Early amps? I was able to test fillament..tests good....ahh forgot to mention there was (I still have) 2.. 316A that look like a door knobs with tiny thin pins..What the heck are these..military? ALSO HAVE 4 RCA CRC8025 that have 4 prongs comming out the side and were in swivel bases that allowed the tube to rock back and forth..I am guesssing..used in navy equipment
2/25/2011 4:04:16 PMRichard
If it is a Cunningham 316, then it should be a type 16 tube. If so it would be a 4-pin half-wave rectifier.
Here is the pinout on it:
http://www.nostalgiaair.org/tubes/16.htm
Richard
2/25/2011 4:24:25 PMGeorge is a 16 same as 81?
:Ok by the way it is NOT tennis ball shape it is a large globe (pear shape) What was this used in? I don't see very often a 81 in my radio restoration
2/25/2011 8:29:18 PMJohn
::Ok by the way it is NOT tennis ball shape it is a large globe (pear shape) What was this used in? I don't see very often a 81 in my radio restoration
George,
The 81 is a direct replacement for the early 16. Half wave rectifiers used in early receivers for a short period of time. Filaments: 7.5V, 1.25 Amps., capable of high plate voltage of 700 volts. Didn't last long due to high filament current draw. FYI: There is a Cunningham CX316B for sale right now on Epay out of Hong Kong...hmmmmmm! Starting bid is $39.99. Just search for Cunningham tubes/vintage and 5 pages will pop up. The 316B is about half way down on page 4.
John
2/26/2011 12:15:16 PMJohn
:::Ok by the way it is NOT tennis ball shape it is a large globe (pear shape) What was this used in? I don't see very often a 81 in my radio restoration
:George,
:The 81 is a direct replacement for the early 16. Half wave rectifiers used in early receivers for a short period of time. Filaments: 7.5V, 1.25 Amps., capable of high plate voltage of 700 volts. Didn't last long due to high filament current draw. FYI: There is a Cunningham CX316B for sale right now on Epay out of Hong Kong...hmmmmmm! Starting bid is $39.99. Just search for Cunningham tubes/vintage and 5 pages will pop up. The 316B is about half way down on page 4.
:John
George,
The 316A was used in the military and had a
VT-191 designation. The triode was good at UHF frequencies and used in transmitters SCR-515/BC645...whatever those were? John
2/27/2011 8:54:34 PMGeorge OMG 2A3 tubes!!!!...
At the bottom of my box i bought at auction I also found 3 2A3 tubes..I see these are going for close to $100.00 bucks each on Ebay...What are they used for and why so dam expensive?
2/27/2011 10:01:09 PMWarren
it's a power triode used for audio output. They are not made anymore. Less become available each day. Similar to like the 45 can go for whatever market will pay.
2/28/2011 4:41:54 PMDoug Criner
2A3s are still made by Sovtek (Russian): http://www.tubedepot.com/so-2a3.html They sell for much less than NOS.
:it's a power triode used for audio output. They are not made anymore. Less become available each day. Similar to like the 45 can go for whatever market will pay.
3/1/2011 11:32:04 AMcodefox
Shuguang (China) also still makes 2A3's and they're pretty good.
