ITT Schaub-lorentz TV 70s display problem
9/30/2001 3:46:21 PMNico
Hey,
You guys must be more techies than I. I just bought an ITT Schaub Lorenz from the 70s, quite round. The problem is that I have just a simple horizontal line in the middle of the screen :(
What should I check ? Any good web site describing this common problem ? Thanks in advance !
Nico
9/30/2001 7:08:19 PMNorm Leal
Hi Nico
Check the Vertical Oscillator and Vertical Output circuits when there is only a horizontal line. Don't keep the line bright as this will burn the screen.
: Hey,
: You guys must be more techies than I. I just bought an ITT Schaub Lorenz from the 70s, quite round. The problem is that I have just a simple horizontal line in the middle of the screen :(
: What should I check ? Any good web site describing this common problem ? Thanks in advance !
: Nico
10/1/2001 10:12:05 PMJohn McPherson
Also remember to check the position of the "Service" switch. These sometimes get switched to the "service" position, and forgotten about. This is especially true if the set was stored around curious children.
: Hi Nico
: Check the Vertical Oscillator and Vertical Output circuits when there is only a horizontal line. Don't keep the line bright as this will burn the screen.
: Norm
: : Hey,
: : You guys must be more techies than I. I just bought an ITT Schaub Lorenz from the 70s, quite round. The problem is that I have just a simple horizontal line in the middle of the screen :(
: : What should I check ? Any good web site describing this common problem ? Thanks in advance !
: : Nico
