MARV
:Would like to get comments on the best spray cleaner for variable caps. I haven't had to do this for a while and now I have one that is very dirty. I've read that spraying the wrong stuff on will leave a residue that will detune a tuning cap. So what's the best no-residue spray?
http://antiqueradios.com/forums/viewtopic.php?t=73596&highlight=ultrasonic
What is the model # of the Ultrasonic Cleaner that you have?
Mitch
Otherwise a circuit spray cleaner and soft bristle brush works well too. Canned air helps as well.
Re-lube the bearings too.
1) Sprays with lubricants are the types that de-tune tuning capacitors. WD-40 is very definitely the wrong stuff!
2) The Spray must be safe for plastics and rubber.
After checking the label on my Radio Shack "Electronics Cleaner" (Stock #64-4345) I concluded it was safe for tuning caps and I went ahead and sprayed my tuner with it. It took off the grime in a jiffy and it did not leave a capacitance changing residue.
PS - I always change the rubber grommets on tuning caps along with using white lithium grease on the ball bearings and this time was no exception.
:If I have to remove the tuner anyway to replace the rubber grommets then I have found that swishing it around well in hot water with dish-soap and a rinse works wonders.
:Otherwise a circuit spray cleaner and soft bristle brush works well too. Canned air helps as well.
:Re-lube the bearings too.
