Hi All, Well I've checked out the AK 40 radio and everything looked good. Check the Ohms on the speaker and there was none (open line). I guess that means the coil is bad. Tried the battery test and nothing. Does anybody know how I can hook up a new style speaker to verify the speaker is bad or know how to fix the coil. Thank You, George.
2/16/2011 1:41:52 AMWarren(93291:93290)
Use an audio output transformer from an AA5 radio and PM speaker. Connect primary to speaker terminals.
Here is a link for Atwater Kent service information. It does cover the E type speaker.
:Use an audio output transformer from an AA5 radio and PM speaker. Connect primary to speaker terminals. : :Here is a link for Atwater Kent service information. It does cover the E type speaker. : :http://www.atwaterkent.info/TechData/akSvcDataIndex.html :
Thanks Warren I have a couple laying around will give it a try. Will also check out the web site.
