Tom Boy radio battery information
2/6/2011 5:00:20 AMrocky walker
I recently acquired a Tom Boy radio it seems to be in perfect condition and I would like to bring it back to life it has the original eveready nine lives B battery once rated at 67.5 volts. I would be grateful to anybody with information as to replacing or improvising a solution to my dead battery it seems like this radio would function if I could get it the proper voltage. Ive been having a hard time finding any info on this little radio I would be thankful for any kind of support thank you.
2/6/2011 5:15:53 AMWarren
Sent you a schematic for a simple B supply.
2/6/2011 2:45:07 PMWarren ( More )
Don't forget your radio also needs the 1.5 volt batteries for the tube filaments. Here is also a link showing your radio. Made by Automatic Radio.
http://www.radiomuseum.org/r/automatic_tomboy.html
2/6/2011 3:34:00 PMBrian
Warren,
Can you send me a copy of the schematic as well?
:Sent you a schematic for a simple B supply.
2/6/2011 3:40:38 PMWarren
Sure can
2/7/2011 9:55:35 PMStephen
Here are some ideas:
1) Connect 45 "AA" batteries in Series, similar to what BatPack.com does with 60 of them for 90 volts.
2) Connect 7 or 8 9-volt alkaline batteries in series. This will create a 63V or 72V
3) Connect 9 Ni-cad 9V batteries in series. This will output 64.8V as these batteries put out 7.2V each
4) Connect 8 9V NiMH batteries in series. These batteries put out 8.4V each and this will output 67.1V
5) Build this inverter circuit that will allow 67.5V to be output from 4 NiMH "AA" cells. This circuit involves adding an inverter containing a logic gate IC, some mosfets, some resistors and some capacitors, a transformer, and a rectifier.
: I recently acquired a Tom Boy radio it seems to be in perfect condition and I would like to bring it back to life it has the original eveready nine lives B battery once rated at 67.5 volts. I would be grateful to anybody with information as to replacing or improvising a solution to my dead battery it seems like this radio would function if I could get it the proper voltage. Ive been having a hard time finding any info on this little radio I would be thankful for any kind of support thank you.
2/7/2011 9:56:05 PMStephen
Forgot to give the URL of #5:
http://www.portabletubes.co.uk/sitefiles/ausbatt.htm
:Here are some ideas:
:1) Connect 45 "AA" batteries in Series, similar to what BatPack.com does with 60 of them for 90 volts.
:2) Connect 7 or 8 9-volt alkaline batteries in series. This will create a 63V or 72V
:3) Connect 9 Ni-cad 9V batteries in series. This will output 64.8V as these batteries put out 7.2V each
:4) Connect 8 9V NiMH batteries in series. These batteries put out 8.4V each and this will output 67.1V
:5) Build this inverter circuit that will allow 67.5V to be output from 4 NiMH "AA" cells. This circuit involves adding an inverter containing a logic gate IC, some mosfets, some resistors and some capacitors, a transformer, and a rectifier.
:: I recently acquired a Tom Boy radio it seems to be in perfect condition and I would like to bring it back to life it has the original eveready nine lives B battery once rated at 67.5 volts. I would be grateful to anybody with information as to replacing or improvising a solution to my dead battery it seems like this radio would function if I could get it the proper voltage. Ive been having a hard time finding any info on this little radio I would be thankful for any kind of support thank you.
