I have all caps done except fot the electrolytics. I am out of 8 and 10 mf caps. Can I sub a 22mf everywhere it calls for an 8 or 10(as I have a lot of 22's)?
I have all the smaller value caps, so they are not a problem.
Steve
I have looked at the schematic and cannot find the voltage values of the E caps, can you post the voltage values?
I would not use a 22 Mfd cap to replace a 8 or 10 Mfd. The solution may be simple when we know the voltage values as these caps can be wired in series to lower the capacitance value of the 22's to meet the value of the other caps.
Again, need to know the voltage values of the E's.
Best regards,
Mitch
I've looked at 3 tube data charts and they indicate 4uf up to 10uf as the 1st cap after the rectifier in a "capacitor input filter" system
Going up to 40uf or better requires input resistance to change the plate impedance.
So it's safe not to exceed 4-10uf.
If all you have is 22uf caps rated @ 450vdc.. you can connect two 22uf caps in series (plus to minus to plus) which will give you a relatively-safe 12uf @ 900vdc
But I'd stick with less than 10 for the 1st cap and the 2nd cap can be anything larger like 22us or whatever.
