L42BG is a ballast tube. Like a wire wound resistor used in series with tube filaments to drop voltage. It drops 42 volts @ 300 ma.
If it's octal there will be resistance between pin #3 and #7 with a lamp tap on pin #8.
:I HAVE FOUND A MODEL 711 HALSON.IT HAS A L42BG TUBE IN IT ,CANNOT FIND TUBE ON N.A. TUBE LIST. NEED TO KNOW PIN LAYOUT
It was made in octal and 4 pin base. Since you have the 4 pin base main resistive element is between pin #1 and #4 with a lamp tap on pin #3. No connection to pin #2.
The tube was mainly used in Emerson DP-332. This one may be similar to your radio?
http://www.nostalgiaair.org/PagesByModel/039/M0005039.pdf
::Hi
:: L42BG is a ballast tube. Like a wire wound resistor used in series with tube filaments to drop voltage. It drops 42 volts @ 300 ma.
:: If it's octal there will be resistance between pin #3 and #7 with a lamp tap on pin #8.
::NORM,THIS TUBE HAS ONLY 4 PINS.
:::I HAVE FOUND A MODEL 711 HALSON.IT HAS A L42BG TUBE IN IT ,CANNOT FIND TUBE ON N.A. TUBE LIST. NEED TO KNOW PIN LAYOUT
