Crosley Model 1117 (Super 11) Power Transformer
2/1/2011 10:12:49 PMRay Inman
I just bought a Crosley Super 11 and the power transformer is shorted and smoking. The short is definately internal and not external to the circuits. Can someone recommend a suitable replacement.
2/1/2011 11:45:14 PMNorm Leal
Hi Ray
Suggest you check here:
Schematic:
http://www.nostalgiaair.org/PagesByModel/235/M0003235.pdf
Can also buy a transformer from AES, www.tubesandmore.com and Radio Daze, www.radiodaze.com .
Didn't try to figure exact requirements but need a transformer with 5 volts @ 2 amps, 6.3 volts @ 3.5 amps and 300-0-300 @ 90 ma or more. You can go higher in current but size gets larger.
:I just bought a Crosley Super 11 and the power transformer is shorted and smoking. The short is definately internal and not external to the circuits. Can someone recommend a suitable replacement.
2/3/2011 9:13:52 AMRay
:Hi Ray
: Suggest you check here:
:http://www.oldradioparts.com/2a23efl.txt
: Schematic:
:http://www.nostalgiaair.org/PagesByModel/235/M0003235.pdf
: Can also buy a transformer from AES, www.tubesandmore.com and Radio Daze, www.radiodaze.com .
: Didn't try to figure exact requirements but need a transformer with 5 volts @ 2 amps, 6.3 volts @ 3.5 amps and 300-0-300 @ 90 ma or more. You can go higher in current but size gets larger.
::I just bought a Crosley Super 11 and the power transformer is shorted and smoking. The short is definately internal and not external to the circuits. Can someone recommend a suitable replacement.
2/3/2011 5:36:05 PMRAY
:Hi Ray
: Schematic:
:Norm;
This is great help...
Ray
