AM Radio Alignment
1/13/2011 5:26:22 PMEdd
Sirs . . . . .
The illustrations on this info is geared towards Daniels current situation, but its info would be equally applicable across the board for other units.
Therefore I posted this as a stand alone posting for referencing such that it could be re-located with a site SEARCH.
If any comments to be added, please place them at the bottom , such that the upper info's integrity will be maintained.
1/14/2011 1:02:14 AMCindy to Edd
:Thank you so much. I just got a new signal generator, frequency meter, and osc. scope...This is exactly what I needed to get started the easy way...Thanks a million. Ps. Is "Edd" an acronym for "Electonic Design Database'? Because you are....
:Sirs . . . . .
:The illustrations on this info is geared towards Daniels current situation, but its info would be equally applicable across the board for other units.
:Therefore I posted this as a stand alone posting for referencing such that it could be re-located with a site SEARCH.
:If any comments to be added, please place them at the bottom , such that the upper info's integrity will be maintained.
1/14/2011 7:10:36 AMScott
Thanks Edd. Your contributions are much appreciated.
Always impressed by your attention to detail in both visual and documented format. Very helpful!
