Fading out 5Y3
1/12/2011 8:42:48 AMjim l
You would think a 5Y3 is either good or bad, but I just had one to fade out after 10 or 15 minutes playing. Quite strange!
1/12/2011 10:35:25 AMEdd
Replied on other thread . . . .
:You would think a 5Y3 is either good or bad, but I just had one to fade out after 10 or 15 minutes playing. Quite strange!
1/12/2011 11:15:18 AMNorm Leal
Hi
Try resoldering filamemt pins #2 and #8. Poor connection here can cause fade out.
:Replied on other thread . . . .
::You would think a 5Y3 is either good or bad, but I just had one to fade out after 10 or 15 minutes playing. Quite strange!
1/12/2011 1:25:25 PMjim l
:Hi
: Try resoldering filamemt pins #2 and #8. Poor connection here can cause fade out.
::Replied on other thread . . . .
:::You would think a 5Y3 is either good or bad, but I just had one to fade out after 10 or 15 minutes playing. Quite strange!
::Thanks Norm and Edd never could see ur comment. I have heated the tube pins hot and maybe solder will make reconnection. Will check it later
1/12/2011 1:54:12 PMEdd
Sir . . . . . Jim
Assuming that you were not seeing my comment . . . it was posted on your other "hiccup" thread as . .
> > > http://www.nostalgiaair.org/Forums/Messages/441/M0092441.htm < < <
::Hi
:: Try resoldering filamemt pins #2 and #8. Poor connection here can cause fade out.
:::Replied on other thread . . . .
::::You would think a 5Y3 is either good or bad, but I just had one to fade out after 10 or 15 minutes playing. Quite strange!
:::Thanks Norm and Edd never could see ur comment. I have heated the tube pins hot and maybe solder will make reconnection. Will check it later
