tube shows short but tests good
1/11/2011 10:17:09 PMPeshi
I bought a NOS 84/6Z4 that shows a short but tests good. I put it in my Eico 625 with the power off and set all the switches, then I turn the power on and get a strong short light but when I hit the test button it tests good. What gives?
1/11/2011 10:24:16 PMJohnnysan
:I bought a NOS 84/6Z4 that shows a short but tests good. I put it in my Eico 625 with the power off and set all the switches, then I turn the power on and get a strong short light but when I hit the test button it tests good. What gives?
That tube should not show a short on any setting. 1 and 5 are the filament, 4 is the cathode and 2 and 3 are the plates. If you have a heater-cathode short it should not be used; it would be like the directly heated cathode rectifiers (5Y3 etc) in which the B+ is present on the filament supply line.
Johnnysan-
1/11/2011 10:42:07 PMWarren
Any NOS tube can be bad. Never know how many times it has been handled dropped, and bouced around. If you look closely, it may even show bent elements.
1/12/2011 7:05:52 PMMike C.
What I'm wondering is,if the shorts light was on,why did you go ahead and test it?The shorts light is supposed to keep you from testing a shorted tube and damaging your tube tester.
1/12/2011 11:02:27 PMPeshi
Just thick I guess
1/12/2011 11:12:16 PMPeshi
Just thick I guess
