If there is room, they can be butt-joined with a copper or aluminum sleeve, which can either be soldered (if aluminum isn't used, and the shafts aren't aluminum), or glued. Super glue or epoxy of your choice (even JB Weld) will work well.
Another method where space is a concern is to cut a slot in the new control's shaft, and then cut the old shaft to fit the corresponding slot. Use glue or epoxy as is applicable. Be sure to cut the old shaft right at the bushing so that there is enough excess that a tooth may be cut to fit the slot in the new shaft.
If that is the one that was soaked in WD-40 that no longer works, you can squeeze together the contacts. Check for good continuity. Clean all contacts with emery paper if necessary, and then scrub the entire switch clean with soap and water. Allow to dry on a radiator or in a 150 degree oven. It should then work well.
The rivets can also be gently tapped with a punch if they are loose. Don't tap so hard as to break the phenolic.
:Hello all,
:I have a rotary switch that i need to replace. I had to purchase a new modern switch and of course the shaft length and style are different. Need ideas on how to facilitate this change/modification.
:If the photo is not here i will continue to post until i get it right.
:Thanks
:Mitch
http://www.oldradioparts.net
Here ‘ya go . . . . and it so happens to even be using a ‘Rat Shack switch in its illustration. |
::Mitch, try Mark Oppat at the link below .
::I have an Emerson U4B (1935, the switch was shot.
::He furnished me a switch with the same shaft but longer in length. All I had to do was install it, cut it to the right length, and file the end to fit the knob.
::That was my first time I have ever did that kind of repair and it works great. I just took my time with it.
::Hope this helps.
::Vinny A.
::http://www.oldradioparts.net
:Vinny,
:I sent them an email regarding the switch with the Philco part # for the band switch.
:Thanks
:Mitch
: : : : ![]() : : : : : : : : :Sir Mitch. . . . . : : : :Here ‘ya go . . . . and it so happens to even be using a ‘Rat Shack switch in its illustration. : : :There is a whole additional texting which accompanies it . . . . but you will have to use SEARCH “edd” to find that info on a prior stand alone post of mine. : : :The "filler" tab is a piece of hacksaw blade cut out with a Dremel tool and a cut off wheel. : : :I had the picture closer at hand than that URL. : : : : : ![]() : : : :73's de Edd : : : : ![]() : |
