Sir Rogers Flipdial. . . . .
My Samuels of that unit is currently out at the “mule barn” . . . . . BUT . . . not to worry . . . as I can ease the locating caps on PCB’s task by approximately 75% for you . . . . PLUS , helping for any other Pee Cee Bee’s in the future.
Have the board where you can make alternate views of foil and component side.
Place a high intensity red laser pointer on the FOIL LAND SIDE, close to where you THINK a capacitors lead wire is coming down from.
And THEN you view from the component side of the PCB.
Move the pointer just to the side of the land such that it will be illuminating THROUGH the board just to the EDGE of the capacitor.
When viewed from the component side, that little glow thru the board should then show you where your pointer is physically located. Then, move the pointer inwards again, towards your perceived guesstimation of the wires location.
Move your eye ball viewing back to the foil side and your pointer should then be resting right atop the land that the wire terminated into.
Mark the land with a blue Sharpie check / dash mark. . . . . . locate that caps OTHER associated wire and its land, mark it, and then circle the two with the Sharpie.
Move on to your marking up of all of the other caps wires in the unit.
And to think . . . . that way y y y back in 1985 . . . I built this apparatus up by using a 5KV gas helium laser driver, feeding into a surplus surgeons fiber optic endoscope.
Now a red $7-8 premium Laser pointer will fill the bill and be small enough to “kiss” the PC board directly.
(Those little pressed tin can cylinder $3 “toy” Lasers won’t quite fill the power output bill . . . take a PCB with you for testing before buying . . . less you have a Laser already. )
(BTW . . .some old blue or green tinted PCB’s really dampen the red spectral pass thru level.)
The next most helpful bit on cap ID will be the use of a dental mirror in reading the cap values printed on their sides, unless you just flat have to pull them out to be able to read values.
I avoid that with some strips of ½ by 3 in clear plastic strips with some shiny chrome foil stuck to the bottom ½ by ½ end so that you have a micro mirror that will let you manipulate in and read values printings as close as 1/8 of an inch to a capacitor.
Thassit . . . .
