Also, I'm replacing the cord and plug with a polarized plug because I've read in multiple locations that this increases safety as well as preventing the radio from being damaged. Should the neutral side of the plug opposite the transformer, like I'm thinking or do I have it all wrong.
I feel a bit embarrassed to be asking this question, but it is much better to be safe than sorry. Thankfully I start school for a bachelors in EE in January so maybe I can start answering a few of these questions for noobs like myself currently.
Thanks in advanced.
SAFETY: Make ABSOLUTELY sure that you are using an isolation transformer when you power this unit up and any time it has power on it. If you have a Variac use this in combination when applying power.
Mitch
Mitch, thanks for the response. Yes, C23 and C22 are in one electrolytic can and C24 is an E-cap across the chassis from the first two. I will ohm it out like you suggested. And yes, I do have an Variac powered from an isolation transformer. Electricity is a great helper, but it is not our friend...
None of these capacitors has its negative connected to the chassis.
Though you can use an ohmmeter to check electrolytic orientation and even test for proper operation, a far better test is with a high voltage leakage tester and capacitor bridge. The ohmmeter cannot simulate what a capacitor is subjected to during normal operation of the radio, and erroneous results can be had both concerning condition and polarity. If a high voltage leakage tester is not available, or you want to be sure about things, it is best to simply replace the electrolytics. If you do have the proper equipment and know what you are looking for, you can re-use some old electrolytics (not that I read any implications of this here).
Gentlemen,
Thank you for all your assistance. I (and I'm sure my friend) thank you.
Ken
A VTVM is extremely sensitive and is very good for control grid circuits, high impedance RF circuits, oscillator circuits, and AVC circuits.
A DVM is rather jumpy and sensitive, and, as Mitch said, can give rather erroneous readings, though is sensitive enough to usually function well where a VTVM would be used, though I prefer the VTVM.
The VTVM and DVM, due to extreme sensitivity, can give erroneous readings when an attempt is made to measure a substantial DC voltage, and small AC voltages co-inside with the DC voltage, such as measuring the voltage of the electrical system of a car. A conventional anolog meter like the Simpson 260 would show the average DC voltage, but the VTVM and DVM might pick up the spikes of the alternator or generator, since the output of both is controlled by pulse width modulation of the field coil, and a generator also contains a commutator, which introduces repetitive voltage fluctuations (as well as the voltage fluctuations due merely to the armature passing the magnetic poles (or vice versa if an alternator)). If there is concern for this problem, and the small spikes and waves might be unwanted (such as in a radio or computer, where clean DC is necessary), a good oscilloscope would be handy here to show the base voltage as well as the spikes.
