Looking for schematic for 1927 pfhansteihl 7 tube overtone
12/29/2010 10:55:51 AMJerry Johnstone
I have a pfansteihl 1927 overtone 7 tube radio lowboy thatI would like to get working but it needs alot of work and i cant'nt go any farther without schematic.
12/30/2010 9:30:16 AMCarl T
:I have a pfansteihl 1927 overtone 7 tube radio lowboy thatI would like to get working but it needs alot of work and i cant'nt go any farther without schematic.
Jerry,
I can't find any schematics for your set.
You might try plugging your tube numbers into this database and try using a schematic for another radio:
http://www.grillecloth.com/sylvania/tubelist.php
12/31/2010 9:37:49 AMjerry
::I have a pfansteihl 1927 overtone 7 tube radio lowboy thatI would like to get working but it needs alot of work and i cant'nt go any farther without schematic.
:Jerry,
:I can't find any schematics for your set.
:You might try plugging your tube numbers into this database and try using a schematic for another radio:
:http://www.grillecloth.com/sylvania/tubelist.php
12/31/2010 10:59:14 AMAlan Douglas
There were several models called the "Overtone". If yours happens to be a 34, there is a schematic in the June 1928 "Radio Broadcast" magazine, page 92. But it's only the radio, not the power supply, and there are no parts values.
1/1/2011 10:34:32 AMNorm Leal
Hi Jerry
Many early radios schematics didn't get published in Rider but are similar. Check Stewart Warner 300 series radios if your radio is battery operated:
http://www.nostalgiaair.org/PagesByModel/794/M0029794.pdf
Pfanstirhl made an Overtone 7 which has 5 tubes. Overtone 10 has 6 tubes.
Your radio having 7 tubes may be AC operated? If so might check Atwater Kent Model 40. Circuit may be similar?
http://www.nostalgiaair.org/PagesByModel/354/M0001354.pdf
:There were several models called the "Overtone". If yours happens to be a 34, there is a schematic in the June 1928 "Radio Broadcast" magazine, page 92. But it's only the radio, not the power supply, and there are no parts values.
1/1/2011 9:44:18 AMjerry
