Just about any output transformer will work. If you have a choice I would use one from a radio with 6V6 or battery output. An AC/DC radio output impedance will be only 2000-2500 ohms.
:Instead of using a high impedance speaker, I would like to connect an output transformer and pm speaker to the output tube, in this case a type 01A running at 135 volts. I have several old radios (battery, AC/DC) from which to pull a transformer and speaker. In coming up with a match, is the load resistance or impedance? more critical than the plate resistance? Are there certain output tubes I should select a radio to pull from that would work better?
:Brian
: Just about any output transformer will work. If you have a choice I would use one from a radio with 6V6 or battery output. An AC/DC radio output impedance will be only 2000-2500 ohms.
::Instead of using a high impedance speaker, I would like to connect an output transformer and pm speaker to the output tube, in this case a type 01A running at 135 volts. I have several old radios (battery, AC/DC) from which to pull a transformer and speaker. In coming up with a match, is the load resistance or impedance? more critical than the plate resistance? Are there certain output tubes I should select a radio to pull from that would work better?
:You can get a miniature xfmr and P.M. speaker, and stuff them in the base of your horn speaker - after removing the old reproducer.
You can further improve the power and tone quality by changing the output tube to a '71A, which takes the same voltage and current as a '01A.
What would the DC resistance be on the primary of a suitable output transformer? I have found severalin 400 to 600 ohm range.
:Brian
Just put in a junk audio output xfmr.
:What would the DC resistance be on the primary of a suitable output transformer? I have found severalin 400 to 600 ohm range.
::Brian
