Crosley 59 Oracle Grandfather Clock Radio 1931
12/29/2010 10:16:03 AMFrank Walls
When i turn the raido on all i get is static when trying to tune raido. I do have it hooked up to a AM antna. but don't no if it is something i am missing no stations are being brought in.Thanks Frank
12/29/2010 7:49:10 PMWarren
Sounds like your radio needs repair. Has anything been done in electronic restoration? Anything tested?
12/29/2010 9:59:28 PMThomas Dermody
Do you get actual 'static' (that crispy buzzy crackly sound AM radios make when between stations), or do you get hum? If you get static and no stations, then the radio needs other repairs, as Warren suggested. If you are getting hum (which some people mistake for static), then you need to replace the electrolytic filter capacitors, as they have likely dried up. I have not consulted the schematic to see if electrolytic filter capacitors are used, but most radios built after 1930 use these.
