:Hello,
:I am going to change the E caps in this radio. One of the caps is 100 Mfd and is connected to the cathode of the 35W4 through a 100 ohm 2 watt resistor. The lagest cap i have is 80 Mfd.
:Will the be ok to use or should i buy a 100 Mfd?
:Thanks
:Mitch
Also, if the radio exhibits no hum and the original units measure proper value with low leakage, and show no physical signs of deterioration, they do not need replacement.
