WVDC is 'Working Volts Direct Current' the maximum safe DC voltage for the cap. '30-50' would be 30 mfd @ 50 volts. '10-350' would be 10 mfd @ 350 volts.
An ESR meter is a good way to test electrolytic caps. If they've sat for many years, I'd test them before using them.
One of the Heath or Solar capacitor analyzers will work well for this.
You can otherwise buy a modern capacitor analyzer that will measure capacitance, and build your own reforming circuit, which will also indicate leakage.
