Does a great job.
Works great with tuners too.
:If I can get the pot out easily I open it and slosh it around in hot soapy dish washing water. Then rinse.
:Thanks to Thom Dermody for his idea on this.
:Does a great job.
:Works great with tuners too.
I can imagine that alcohol may clean pots well, too. It can be applied with a cotton swab.
In some cases the best fix has been WD-40, and in many of these cases I have had practically permanent good results. However, in other sensitive cases, I have had trouble result from carbon deposited in the WD-40 forming a leak to the pot's housing, which, in those cases, caused trouble (such as the very high impedance vertical hold circuit in my DeWald BT-100 television).
I decided on dielectric grease from finding some new pots with silicon type grease on the resistance material. It can work well, and occasionally it won't work well. With adequate spring tension (though not too much) it should work well. It remains on the resistance material, and doesn't get all over the pot, which is why I usually prefer it to WD-40, but there are cases where WD-40 just works so much better.
All of the methods described here in this thread will work well, and all will have their exceptions.
I have used WD-40 on stuck light switches with good success, but there the problem is not starting a fire, for the first few times you turn the light on and off there will be a small blue flash within the switch.
