I have this Atwater Kent model 46 that actually worked when I got it but I knew it had some problems so I'm recapping it and installing new resistors. I'm following instructions written by D. K. Owens in 2000 I believe. It says "The Old Timers Bulletin/May 2000". The part I'm at now says "Look carefully at the pack. There is a wire going from the left compartment into the center compartment. This is the B+ input from the rectifier tube. Leave this wire alone". I have two wires as noted in this picture I'm gonna try to post. One is red coming from the mallory cap and the other is green. I think. There is also a "Mallory" cap that I can't identify. The one I just mentioned with the red wire. The R/H compartment is not shown in this picture. It has the capacitor bank in it and it is the later version and I have it removed. So let me try to post this pic.
:[img]http://www.speakeasyradios.com/yahoo_site_admin/assets/images/AK46_Power_Pack_001.357115248_std.jpg[/img]
Lets see if I put a pic here. If so I'll continue or try again on the pic.
Johnny
Johnny
Going from the "Left Section" to the "Center Section" there are two wires. One of these is supposed to be B+ from the 80 rectifier. That's what the instructions from the restoration instructions says. It also says there should "Be a wire" but there's two. The red and the green. The red wire comes off of one end of the unknown cap. Other end of that cap is chassis grounded. The green wire goes from tar to tar.
So has anyone worked on one of these and knows what the "Mallory" cap is? Is it a cap? Which wire, red or green is the B+?
Thanks much and have a Merry Christmas,
Johnny
...Though hopefully in the next few days someone on here will be able to identify that capacitor. However, I put off buying a good capacitor analyzer over and over again, and now that I have one I cannot say enough how nice it is to own one. Modern capacitor 'checkers' are alright, too, but lack high voltage for leakage tests. A modern capacitor checker that also has an insulation tester might work well for higher voltage capacitors.
Johnny
http://www.atwaterkent.info/TechData/akSvcDataIndex.html
For original Atwater Kent Data and modern drawings check this site:
If you are unsure about specific wires going into the tar use your ohm meter. On one lead attach a pin. This pin can poke through wire insulation.
Caps can be replaced by removing a little tar from the top. Plenty of room for modern electrolytic caps.
:When you have an unknown mess like that, before applying any power to it. Have a look at this site for your model Atwater Kent. It does show good schematics and color wire information. You should be able to logic it out.
:http://www.atwaterkent.info/TechData/akSvcDataIndex.html
Johnny
Johnny
