I am schematically evaluating that switch as only having TWO separate A and B active sections. |
Might try an old computer data switch box. The rotary switch can be just A & B or some have A-B-C-D .. The switch has multiple contact points, but can be wired to fit your needs.
: : : : ![]() : : : : : : : : :Sir Mitch. . . . . : : : :I am schematically evaluating that switch as only having TWO separate A and B active sections. : : :One section is a spdt rotary action that switches B+ for the AM-FM transitioning. : : :The other section is also a spdt rotary action that switches audio level signals . : : :You may have some reeeeaaaal Wierd Albert mechanical construction, on that unit, but only the above switching basics are the ones that need to be met. : : :As per the consideration of the shorting . . . .e.g . . . make before break action . . . versus . . . non shorting type of switch . . .that is no real problem . : : :If using a non shorting type, you will merely have a quick "pop" during band transition on the radio . . . . IF being running while doing the band switching. : : : : : : :73's de Edd : : : : ![]() : |
As Edd said, a break before make switch will work just fine in this application. Actually, this kind of switch will work just fine in almost all radios. Temporary voltage spikes and changes are of no concern for most radios (that is, unloading and loading the B supply, when this is done by the rotary switch). There are rare exceptions to this, I'm sure, but it's not typical. Very early radios where the speaker field is across the B supply will suffer damage (sometimes) if the speaker field is removed from the circuit while the radio is in operation. However, I don't know of any radios in which the speaker field is switched, so this is an unlikely situation unless one physically disconnects the speaker.
Anyway, if that Radio Shack switch has three sections and two positions (or more), then use it. It will work well.
