curtis mathes music center
1/29/1999 2:22:47 AMJeff
This music center consists of a stereo,
tv, and turn-table. I just want to get the
stereo to work. I've replaced many of the
tubes, but no luck. How come my glow tube
(6E5) doesn't even light up? Is this a
power supply problem and not tubes?
The turn table works, I've hooked up a
CD player to the tape inputs and that
works, but that's about it.
Any advice for an amateur.
1/29/1999 9:51:09 AMNorm Leal
: This music center consists of a stereo,
: tv, and turn-table. I just want to get the
: stereo to work. I've replaced many of the
: tubes, but no luck. How come my glow tube
: (6E5) doesn't even light up? Is this a
: power supply problem and not tubes?
: The turn table works, I've hooked up a
: CD player to the tape inputs and that
: works, but that's about it.
: Any advice for an amateur.
Hi Jeff
Since your CD player works, connected to the tape inputs, you may not have a power supply problem. The 6E5, tuning eye, usually lose green glow long before other tubes fail. Look closely you may see a faint green when the unit is operating. If you have a meter, check pin #4 on the tube. It should have around 250 volts.
To help with repairs you may want to list, on the forum, what you have tried and what still doesn't work.
1/31/2000 2:43:39 PMYolanda Bryan
:I have a very old curtis mathes vcr. model # JV753
I cannot find my instruction manual. Where can I locate another one.
I need to be recording, but can't get it to work. Anyway I need a manual.
Thanks.
