As the level is turned up the clipping of low frequencys increases.
Frequency response of Radio Shack ground isolator. Bottom trace if output from sweep generator, top trace is out of unit. Sweep if from 40 HZ to about 15 KHz. Voltage of input and output is apx. 1.25 volts.
